General Information
Troubleshooting
smoking rabbit
Topic: smoking rabbit (Read 5811 times)
December 23, 2006, 07:07:53 am
jake zak
Newbie
smoking rabbit
December 23, 2006, 07:07:53 am »
I bought a 82 rabbit that smokes.
its fuel or oil smoke,its pretty heavy,can not smell antifreeze.does not overheat.
took the injectors out and compression was 375+ on every one.
put used injectors in and set valves.started up and still smokes to excess.
runs smooth and tacks up fast....
did anyone ever come across this?
maybe the pump?
or valve seals?
the story I got was that the guy who owned it tried to start this with bad glow plugs......
when it started it was smoking.(it has a block heater,and said he did not use starting fluid)...
thought I would run this across to you all before I change the pump.
thanks
December 23, 2006, 09:15:04 am
g-spec
smoking rabbit
December 23, 2006, 09:15:04 am »
what colour is the smoke??? if its black than it is fuel....if its blue smoke than that is oil burning!!!!
colour will tell a lot!!!!
December 23, 2006, 10:20:07 am
Darkness_is_spreading
December 23, 2006, 10:20:07 am »
Yea man you have good compression, def IP, or Fuel pin on the front of the pump, but yes check the help section
92 Jetta 1.6 T (Sleepin)
December 23, 2006, 03:47:38 pm
jake zak
Newbie
smoking rabbit
December 23, 2006, 03:47:38 pm »
I will post it in help section thanks
it is a bluish smoke.the injectors I had from another engine had not much miles since rebuild.
pump timing is right on also.
but it was strange.....
now that I think about it,the pump was (fuel shut off was disconected)flipping some fuel out of the nozzle ports on the pump while taking the compression test..
jake
December 23, 2006, 04:16:06 pm
SMOKEYDUB
smoking rabbit
December 23, 2006, 04:16:06 pm »
dirty injectors maybe. injector could be leaking down into the cyl. sounds like the engine is quite tired. Its most likely the cylinder head needs rebuilt but check blow by and maybe do a cylinder leak down test.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
December 23, 2006, 04:35:35 pm
jake zak
Newbie
smoking rabbit
December 23, 2006, 04:35:35 pm »
this has 166K miles on it.
Am told it never had the head off also.
no smoke from blowby,had top hose and air box off when running.
also no oil in the air box?
seems like maybe valve guide seals.
maybe the oil to thin?
I don't think two different sets of injectors would do the same thing(smoke).
jake
December 23, 2006, 04:39:16 pm
SMOKEYDUB
smoking rabbit
December 23, 2006, 04:39:16 pm »
if the engine was sitting a while without running the valve seals can dry up and crak and leak oil on to the gide which would go down into the intake port. I just thought of this it could be your turbo leaking oil check how much play it has.
(courtesy of GILES)
December 23, 2006, 04:43:25 pm
jake zak
Newbie
smoking rabbit
December 23, 2006, 04:43:25 pm »
this is a N/A stock 1.6 engine.
December 23, 2006, 08:44:27 pm
smoking rabbit
December 23, 2006, 08:44:27 pm »
if you're getting no blowby, then its quite possibly the rings. the ring gap is probably pretty big by now, and letting just enough oil seep through to create the blue haze out the exhaust.
usually once warm they idle very well. its only under high stress/boost that the motor burns the oil. (extreme heat & pressures)
black smoke out the tailpipe is also a sign of possible oil burning as well. funny that rotella t doesn't burn like other conventional oils do though... only other oils that can do that are synthetics.
December 24, 2006, 08:39:09 am
jake zak
Newbie
smoking rabbit
December 24, 2006, 08:39:09 am »
this morning went out there and pull the cold start and fired on the touch of the key and no smoke?
pushed it in and OH NO SMOKE....
timing is right on the marks..
thanks
December 24, 2006, 10:47:49 am
smoking rabbit
December 24, 2006, 10:47:49 am »
thats awesome! how cold was it?
Reply #11
December 24, 2006, 10:48:58 am
jake zak
Newbie
smoking rabbit
Reply #11 on:
December 24, 2006, 10:48:58 am »
46 degrees.
I will have to advance the pump,and try that...
General Information
Troubleshooting
smoking rabbit
