Author Topic: TD vs NA heads - how do I tell the difference?  (Read 7296 times)
Reply #15November 23, 2009, 11:08:08 pm
Re: TD vs NA heads - how do I tell the difference?
« Reply #15 on: November 23, 2009, 11:08:08 pm »
I was always told that all VW reman heads were TD spec.  Initially, the NA and TD heads were different- either casting, valves, or both, but all factory reman heads are supposedly the same.
I don't know that for sure, just going on what I've read.
I read that the TD heads and exhaust valves were a slightly different metal than the NA's so I don't see how they could change the heads metal without completely melting it down and starting over ???
