Author Topic: Stinky got his bloodwork back! (oil analysis report)  (Read 6958 times)
Reply #15December 13, 2006, 03:50:36 pm
Rat407
  • 289
« Reply #15 on: December 13, 2006, 03:50:36 pm »
Glad to see someone else has an oil report on a 1.6. I had mine done as well in my 91 ECO Jetta. I posted on BITOG.COM  Yours isn't to much different than mine except for the iron and since I have an oil pressure problem that I think explains mine iron.  Check it out here
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #16December 13, 2006, 05:09:48 pm
« Reply #16 on: December 13, 2006, 05:09:48 pm »
ACCESS DENIED :(
Reply #17December 13, 2006, 06:05:02 pm
Rat407
  • 289
« Reply #17 on: December 13, 2006, 06:05:02 pm »
Don't understand why you can't view it but here is what I posted.
1991 VW Jetta Turbo
Total miles 19,477 (since rebuild)
Miles on oil 6,230
AMSOIL 15w-40
Oil filter Mahle OC51
Air filter Mahle Paper
Sample date 11/01/06
Oil was in vehicle for 5 months. 2Qt makeup
First run with AMSOIL, before this was Rotella
Mix of highway and city miles put on vehicle
Aluminum..........6
Chromium..........4
Iron.................99
Copper..............6
Lead.................3
Tin....................1
Molybdenum.......5
Nickel................1
Manganese.........1
Silver................0
Potassium..........0
Boron...............18
Silicon..............4
Sodium.............3
Calcium.........3717
Magnesium.......29
Phosphorus......1028
Zinc................1166
Barium.............0
Viscosity………….81.3
Flashpoint F…….440
Fuel%..............0.5
Coolant%………..0.0
Water%……………..0.0
Insolubles%......0.4
TBN/TAN…………..9.9
I had the engine completely rebuilt three years ago this coming spring. I have an oil pressure problem, that being I have no oil pressure at operating temp. I get 20psi at cold start up but when the oil warms up it drops to zero and stays there. The gage is good as everything in the engine is new. That oil pressure reading is at the head. I have oil volume just no pressure. If you take my cam cover off you will get soaked by the oil that flows up there around the cam and lifters. Engine smokes on startup. The shop that did the head messed up on it obviously for the smoke I'm getting. I go through a qt of oil every 3k miles. Running a stock Mahle OC51 oil filter and a stock Mahle paper air. The injection pump has been rebuilt and tweeked so I'm getting plenty of fuel. If I run up the RPM's with about 15PSI of boost I can get a nice black cloud of smoke. Needless to say nobody tail gates me. I get lifter tap, some days bad and some days not at all. I figure it is from the oil pressure issue. I just turned 20k total miles on the engine since I had it rebuilt. It was broke in on Rotella SAE 30 for the first 500 miles and then 3k after that and then 15w-40 rotella at 3k miles up until I put the AME in. I always run a Mahle OC51 oil filter. I had the K14 turbo rebuilt when I did the engine and I installed a 2.5" down pipe off the turbo and it runs 2.5" all the way back to a flowmaster muffler. My best fuel mileage has been 52.7mpg. On average I get 46-49. This sample I have ran about 14 gallons of waste veggy oil mixed in with the diesel at a 50/50 mix. It sure seemed to like that, ran smoother than on regular diesel and smoked less. That is about all I can think of for now. Again, comments welcome.
1991 Jetta  ECO TD
Reply #18December 13, 2006, 06:38:51 pm
« Reply #18 on: December 13, 2006, 06:38:51 pm »
Do you have an oil pump for a mechanical head installed on a hydrolic lifter head?
Reply #19December 14, 2006, 12:14:59 am
Rat407
  • 289
« Reply #19 on: December 14, 2006, 12:14:59 am »
Quote from: burn_your_money
No. I changed the pump out twice just in case and it is for a TD.  I'm thinking there is an issue with the head its self. Something with the casting. From reading the previous owners maintenance records all was well with the car up untill he broke a timeing belt and had the head replaced at 110K. Then when the car was in for maintenance after that for what ever reason the service department noted a few times on the oil pressure light coming on but the oil level was full.  I have oil flow/volume just no pressure. If you take the cam cover off you would get soaked from all the oil up there around the cam.
1991 Jetta  ECO TD
Reply #20December 14, 2006, 04:29:03 am
« Reply #20 on: December 14, 2006, 04:29:03 am »
the pump is for a TD, but there is a huge difference between the hydraulic pump and the mechanical pump.   the hydraulic lifter engines require a bigger pump to deliver more oil.  if you have the mechanical lifter oil pump, then that would explain the low oil pressure.
um as far as i know, oil should not be 'spraying' you at idle.  maybe there is something that is releasing all the pressure up top... which is not good for the rest of the engine.. such as the oil squirters (they require 1.7 bar to open... therefore you are not getting the benefits of piston cooling)
i would definitely get it checked out asap.  wouldn't want to ruin a nicely rebuilt motor!
