Author Topic: Consequences of High EGT's?  (Read 8845 times)
Reply #15December 08, 2006, 09:30:57 am
saurkraut
  • 904
« Reply #15 on: December 08, 2006, 09:30:57 am »
"I did adjust it, but not enough to affect idle.."
Well, in that case, i doubt you had an EGT related failure.  I suspect the valves/guides were incorrectly installed.  Do it your self, or find another shop.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #16December 08, 2006, 09:38:25 am
myke_w
  • 1099
« Reply #16 on: December 08, 2006, 09:38:25 am »
I wish I had the seat cutting and valve facing equipment because I would do it myself. I should probably just bite the bullet and sbuy the stuff. Anybody got ideas on where to find stuff like that? I accustomed to using the kind of cutter that has the tungsten carbide bits and use the valve guide as a centering point..  Any particular brand that are better than others?
Reply #17December 12, 2006, 06:58:41 am
saurkraut
  • 904
« Reply #17 on: December 12, 2006, 06:58:41 am »
I've had good results just lapping in the new valves with out remachining the valve seats.  test fit your valves in the guides that are in the head now.  They should slide easily with a spot of oil.
You could try all new valves, reaming the tight guides, and lapping in the valves.  Probably not the most correct way to do it, but it has served me well.  If you have a couple seats that don't look like the contact area is wide enough, just remachine those.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #18December 12, 2006, 09:49:18 am
myke_w
  • 1099
« Reply #18 on: December 12, 2006, 09:49:18 am »
Actually I found a company that sells a really sweet setup for cutting seats and driving / reaming guides. It's less than 400 bucks for the setup and uses tungsten carbide bits like a brake machine, and will do virtually any VW motor (gas diesel etc).  I've used this setup before at a freind's shop and it's second to none..
see site... http://www.newaymfg.com/frame.htm
The guy I spoke with was extremely knowledgeable and knew exactly what I was talking about.. We debated the use of stones etc and talked a bit of theory.. anyway.. This solves at least one part of my problem.. :)
