Author Topic: Replacing dist. head o-ring  (Read 3519 times)
May 16, 2004, 11:43:44 am
DieselsRcool
  • 152
« on: May 16, 2004, 11:43:44 am »
I have a pump on the 1.6D in my Samurai that is leaking a drip every 2 seconds. it seems to be coming from between the distributor head and the pump body. Seems I read somewhere about changing this without pulling the distributor head all the way off. I'm thinking one could back out the bolts enough to get to the o-ring. Then remove one bolt at a time, pull the o-ring  over that bolt and put the new one under it at the same time. Does this sound doable?
Question:
Is this a standard o-ring? If not, does anyone know where I can get a new one?
