Author Topic: Running ATF  (Read 4476 times)
December 01, 2006, 02:43:50 pm
Running ATF
« on: December 01, 2006, 02:43:50 pm »
I want to run half a tank on pure ATF but I don't know how good that will be for my car. When ATF is in the fuel filter during changes it is diluted by the diesel already in the pump so it wouldn't be as high of a concentration as if I just filled my tank half full with ATF.
Will my car run fine on pure ATF? I don't care about mileage, or how well it runs, I just want it to run and clean. The car has around 438xxx kms on it so I'd like to give it a good cleaning. The IP was rebuilt about a year ago though.
What about cold starts (It's around -15 in the mornings)? Any converns with gelling?
I do plan to change the fuel filter after this.
If biodiesel was available and it didn't eat my lines I'd run that instead but I don't want to be changing lines in the winter.
Reply #1December 01, 2006, 02:49:57 pm
Running ATF
« Reply #1 on: December 01, 2006, 02:49:57 pm »
aside from injectors and the pump, it is a bad idea to do stuff to clean the engine, it can loosen carbon deposits and lower your compression, and although atf is not like a crank case additive, it is still  oil that some will make it past your rings and stuff.... but i don't really know for sure, just throwing ideas out there.  atf is an awesome lubricant though.
Reply #2December 01, 2006, 02:51:03 pm
Running ATF
« Reply #2 on: December 01, 2006, 02:51:03 pm »
So a carbon run is not recommended? or an italian tune up?
Reply #3December 02, 2006, 07:13:59 am
saurkraut
  • 904
Running ATF
« Reply #3 on: December 02, 2006, 07:13:59 am »
A long time ago, I used to put a quart of ATF in my tank at every oil change.  After doing this for quite a while, i had to remove my injector lines for some reason, probably an injector check.
Anyway, i looked at the ends of the injector lines were they attach to the injector and noticed that they had little slots eroded in the id of of the line in a pattern that followed the fuel flow into the injector.
I haven't run ATF since, and I haven't seen this errosion pattern either.
Go figure
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #4December 02, 2006, 07:55:18 am
Running ATF
« Reply #4 on: December 02, 2006, 07:55:18 am »
if you wanna clean things up run a can of purge through, the difference before and after is very noticable, and the can is only like 10 bucks
Reply #5December 03, 2006, 09:48:53 pm
Running ATF
« Reply #5 on: December 03, 2006, 09:48:53 pm »
Quote from: "Trev0rbr"
Yeah that's tricky stuff to find, but I have a lead on some. Fuel line erosion does not sound pleasent...
Reply #6December 05, 2006, 08:43:17 pm
sethyboy85
  • 284
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #7December 06, 2006, 07:39:53 am
monst
  • 184
Running ATF
« Reply #7 on: December 06, 2006, 07:39:53 am »
Purge? what is that?
 Burn your money ..
what about biodiesel?
that'll clean it out..........
Reply #8December 06, 2006, 02:28:08 pm
Running ATF
« Reply #8 on: December 06, 2006, 02:28:08 pm »
biodiesel does clean them out real nice too. i know a guy that had a questionable pump and after running biodiesel for a while it seems to be in good health.  biodiesel isn't as instant as purge, but i think biodiesel eventually does a better job, especially since it sits in your pump constantly
Reply #9December 06, 2006, 03:16:37 pm
Running ATF
« Reply #9 on: December 06, 2006, 03:16:37 pm »
Quote from: "monst"
 Burn your money ..
puge = diesel purge. It's a cleaner that you run through the engine. Unhook the feed and return lines from the fitler and stuff them in the can.
Biodiesel is not available in my area (yet, hoping) Plus I don't want to have to change all my lines
I will make my own biodiesel in the summer, and I'll probably run the ATF diesel purge style. Just mount a jug in the engine bay and drive around the block when the engine is already warm to avoid hard starting. Or just let it idle away for a few hours
Reply #10December 06, 2006, 08:25:48 pm
LeeG
  • 401
Running ATF
« Reply #10 on: December 06, 2006, 08:25:48 pm »
thats funny, our biodiesel comes from Quebec rendering plants, some from midwest soy plants.
'97 Passat TDI
Reply #11December 07, 2006, 12:39:53 pm
monst
  • 184
Running ATF
« Reply #11 on: December 07, 2006, 12:39:53 pm »
changing out the lines is not a really big deal...
cost wise.....
I did alot of research on this..... here is what
you can do.......(one approach)........
http://www.mcmaster.com...
search using viton... select viton tubing.....
that will bring you to the link.
here you can get all the tiny return lines (viton)
Yeah, i think it was 1/8 id.......
I think I got like 2 feet for 7 bucks....
As for the 1/4 and 5/16 lines... viton
is too much cash for me......
I might have bought 3' of 1/4 and 5' 5/16..
This is the rating on the hose your are looking
for.....SAE J30R9.... Soceity A?? engineers.....
All these hoses are biod compat......... if sae j30r9
  This brand Dayco... makes a line
 it is called Gen II(2) Dayco GenII fuel injection line.....
Just make sure on the line it says Gen II and saej30r9
 you can check it out
http://http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/1f110345eb637790862571aa006e7b5c?OpenDocument
The cost is significantly cheaper.
I replaced all those hoses for around 40bucks......
and I put on some fuel injection hose clamps......
for another 10......
[/url]
