Author Topic: Low Sulfer  (Read 5053 times)
November 30, 2006, 11:18:36 pm
mk1TD
  • 2
Low Sulfer
« on: November 30, 2006, 11:18:36 pm »
What do we do about the ULSD fuel?  I understand that diesels rely on sulfer content in the fuel to help lubricate injection componients.  With the fuel now having less than 15 PPM when it was about 500 PPM that has to have some effect on injection componients I would think.
 So what is everybody doing to restore the sulfer content in diesel fuel?
Reply #1December 01, 2006, 03:15:20 am
Low Sulfer
« Reply #1 on: December 01, 2006, 03:15:20 am »
originall it was 5000, they cut us down alot over the years lol, alot of people are putting additives in it, i'm not concerned quit frankly, i already used additives and still do, but its cause they make it run better regardless, ulsd has additives for lubrication, i don't know why every is so scared... do you really think they'd change it on us when it would obviously break every mechanically injector diesel on the road, which i'm going to assume is the vast majority of them.
Reply #2December 01, 2006, 06:31:47 am
FineFrank
  • 72
ULSD
« Reply #2 on: December 01, 2006, 06:31:47 am »
It's not the sulfur that lubricates, but when the refineries remove the sulfur, they remove the stuff that lubes too.
There's been an interesting thread (albeit hard to follow) over at vwdieselparts.com- Hagar has been adding canning wax in the summer and Aeroshell 120 in the winter to his NA bunny to raise the viscosity of the fuel (which provides lubrication). I used canning wax last summer, and didn't notice any performance change, but the motor ran a bit quieter.
I'm currently using Costal ND40 in my fuel and I'm going to use Aeroshell 120 next fill up.
Some of the mechanics at the school bus garage are adding inexpensive two stroke oil to their fuel. I'm not clear on which to use, air cooled oil or water colled oil, so I'm a bit leery about it. I'll see how the injectors look next month and go from there.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #3December 01, 2006, 10:38:07 am
AdAm84
Low Sulfer
« Reply #3 on: December 01, 2006, 10:38:07 am »
the only thing that i really heard negative is that it will clean your system out. so i'm gonna run a tank through then change my fuel filter. but our 6.5L turbodiesel suburban has had no problems and we ran it for like two months before our supplier told us it had been switced. i dont think it really makes a difference.
Reply #4December 01, 2006, 10:41:19 am
Op-Ivy
  • 513
Low Sulfer
« Reply #4 on: December 01, 2006, 10:41:19 am »
Quote from: Trev0rbr
I wasn't concerned either until the seals in my fuel pump started shirking due to a loss of size because of the new fuel. Now I am probably going to just rebuild the entire pump eventually...
Yes I do. Problems with fuel viscosity will not affect newer diesel engines as much as it will older ones. You have to remember that half the world is trying to reduce emissions. Older cars, diesel or not, will polute more than a newer engine that has to go through more strict emissions testing then ours ever did. I'm sure that they aren't purposly trying to destroy our cars, but I wouldn't be surprised if they were trying to weed us out.
Reply #5December 01, 2006, 12:41:41 pm
myke_w
  • 1099
Low Sulfer
« Reply #5 on: December 01, 2006, 12:41:41 pm »
I'm really surprised nobody has mentioned a biodiesel blend as a solution.. It has high lubricity and raises cetane, and has some aromatics that may help maintain seal swell inside the pump.. it's about the cheapest solution you can find per gallon..
Reply #6December 01, 2006, 02:29:53 pm
Low Sulfer
« Reply #6 on: December 01, 2006, 02:29:53 pm »
the mechanical pump isn't like an old thing though either that only people with 80s cars need to worry about,  tdis up into the mk4's have mechanical pumps, althought computer controlled, they still need good lubrcation, this is the same for dodge pick ups up until 98 and many other vehicles...
Reply #7December 01, 2006, 02:38:31 pm
Low Sulfer
« Reply #7 on: December 01, 2006, 02:38:31 pm »
I either use air cooled 2 stroke engine oil or the C-tire stuff. I have lots of differant lubes/additives in my shed, it just depends on what I put in my trunk. I don't notice any differance with them but it's cheap insurance at the very least.
Reply #8December 02, 2006, 03:18:38 am
Low Sulfer
« Reply #8 on: December 02, 2006, 03:18:38 am »
well my pump is leaking ulsd all over... thats my only real complaint.  they do add lubrication additives though...
maybe this explains why diesel is going up in price... the extra refining process to get rid of sulphur, and mixing additives...
Reply #9December 02, 2006, 07:50:30 am
Low Sulfer
« Reply #9 on: December 02, 2006, 07:50:30 am »
from what i have heard once the change over from old diesel to this new crap is done the price should start to come down, either way i don't care i barely spend 20 bucks a week on fuel and i drive alot
Reply #10December 02, 2006, 01:16:45 pm
firestorm13666
  • 204
Low Sulfer
« Reply #10 on: December 02, 2006, 01:16:45 pm »
One thing i can say about ULSD is there is going to be more water getting into your fuel.I work at a truck stop shop and we have been seeing more and more fuel filters problems because of water in fuel.
Reply #11December 02, 2006, 01:19:41 pm
Low Sulfer
« Reply #11 on: December 02, 2006, 01:19:41 pm »
Quote from: firestorm13666
just another reason to use additives now more than ever...  this is excellent information.  i absolutely love this forum!
Reply #12December 02, 2006, 02:37:18 pm
Op-Ivy
  • 513
Low Sulfer
« Reply #12 on: December 02, 2006, 02:37:18 pm »
I actually replaced my fuel filter last week and I drained quite a bit of water out. I decided it was because I hadn't drained it in a while, but the ULSD could be the reason as well.
Firestorm, why does the ULSD do this?
Reply #13December 02, 2006, 03:18:24 pm
firestorm13666
  • 204
Low Sulfer
« Reply #13 on: December 02, 2006, 03:18:24 pm »
I am not sure why myself as i am still learning about diesel's.I think it is because diesel has the habit to absorb water.
Reply #14December 02, 2006, 03:28:13 pm
Low Sulfer
« Reply #14 on: December 02, 2006, 03:28:13 pm »
So how many tankfuls can I run before I have to drain my filter? I get kind of lazy with maintenance in the winter... for some reason -20 and cold metal don't excite me
