Author Topic: TDI vs TDI-m/TD-IDI with VNT  (Read 4859 times)
November 21, 2006, 02:23:17 am
Benjamin
  • 485
« on: November 21, 2006, 02:23:17 am »
When you tune a (electronic) 1.9TDI, you can go till something like 200hp with stock turbo (gt1749vb), if you want more, you need to go for a bigger turbo, some guys tried a gt2052v, but it spools very bad.
when guys on this forum put the gt2052v on a 1.9TDI-m/TD is spools very good.
Can someone explain this? (or correct me if i'm wrong :wink: )
Greetz, Benjamin
Must make +250hp
Reply #1November 21, 2006, 08:18:48 am
Tintin
  • 1279
« Reply #1 on: November 21, 2006, 08:18:48 am »
Look at this video, normal shifting 1,2,3,4,   towards the end, i put the accelerator on the floor ........  boost instantaneously.
http://video.google.fr/videoplay?docid=2328693919539972270&hl=fr
I have a 12mm pump head with .240 nozzle,  with 10mm pump head and smaller nozzle, the boost reaction is slower,  but it is acceptable.
Reply #2November 21, 2006, 08:55:01 am
QuickTD
  • 1156
« Reply #2 on: November 21, 2006, 08:55:01 am »
The TDI electronics won't allow a lot of fueling until boost pressure is present, and a large turbo requires alot of fuel (and some off-boost smoke) to produce boost quickly. Sort of a catch 22 situation.
 A custom map that allowed a good amount of smoke off boost would help, thats what the mechanical pump guys do...
Reply #3November 21, 2006, 10:41:51 am
Benjamin
  • 485
« Reply #3 on: November 21, 2006, 10:41:51 am »
Quote from: Named Tintin
Yeah smaller nozzle's, but the guys who put a bigger turbo also have the bogger nozzle's. (i dont think there is any difrence in the punger & head for this discussion)
QuickTD, sounds good theory, but i wonder the electronics are so good secured.
I heard saying from a professional tuner, a 1.9TDI with a GT2052v should start making boost on 3000-3500rpm.
Greetz, Benjamin
Must make +250hp
