Author Topic: Read somewhere on here about a boost controller.........  (Read 5108 times)
November 18, 2006, 01:55:53 pm
MontanaGTD
  • 230
    • http://www.dub-style.com
« on: November 18, 2006, 01:55:53 pm »
Where does it fit exactly and does it make much difference? What other mods need doing first?
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1November 18, 2006, 04:22:14 pm
« Reply #1 on: November 18, 2006, 04:22:14 pm »
BOV mod first will help.
I get full boost about 500 RPM earlier, and don't bog on upshift anymore with the mod.  I set it to 1 bar, so I'm only a little over stock on max boost.
After, y9ou may be able to turn up t he fuel a little before smoke happens, but a pyrommeter would be good before that.  In my case adding boost without fuel didn't make much change to the EGT.
Oh the controller goes in the sinal line from the intake to the wastegate.
here is a small write up...
http://www.gusmahon.org/html/boostcontrol.htm
Reply #2November 18, 2006, 04:33:53 pm
MontanaGTD
  • 230
« Reply #2 on: November 18, 2006, 04:33:53 pm »
Is that the same pipe the boost gauge goes into?
MK3 Polo G40 - Sold
Reply #3November 18, 2006, 05:06:17 pm
« Reply #3 on: November 18, 2006, 05:06:17 pm »
loook for 1 or 2 hoses on the turbocharger body.
Reply #4November 20, 2006, 04:21:53 am
MontanaGTD
  • 230
« Reply #4 on: November 20, 2006, 04:21:53 am »
Can someone show me a picture of the pipe the controller is to go into? Mines a 1991 1.6 TD (SB engine code) (I'll post up a picture later!)
MK3 Polo G40 - Sold
Reply #5November 21, 2006, 07:05:20 am
veeman
  • 421
« Reply #5 on: November 21, 2006, 07:05:20 am »
Not sure if your turbo is the same as mine (Garrett) but here you go...
See the longer of the two black hoses there?  You essentially put the boost controller in line with that.  It controls the amount of pressure that the wastegate "sees".  On mine, I simply got two longer pieces of hose and put the controller in between them.  I've probably got a pic of that somewhere if you need to see it.
You definitely need to block the pop-off valve before doing that or else you'll be venting all your boost once you try to increase it.  There's an excellent write up in the archives about doing this with a bolt or capping it off altogether with a piece of metal / wood.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #6November 21, 2006, 04:54:56 pm
MontanaGTD
  • 230
« Reply #6 on: November 21, 2006, 04:54:56 pm »
Is it best to run the boost controller into the interior ir leave the adjuster under the bonnet hidden away?
MK3 Polo G40 - Sold
Reply #7November 21, 2006, 05:10:37 pm
« Reply #7 on: November 21, 2006, 05:10:37 pm »
Quote from: MontanaGTD
i'd say it would be best to have it in the interior...  that way you can adjust it while watching the boost gauge and driving.  otherwise you will need to drive it. stop open hood, adjust, get back in and drive.  would probably be a PITA
Reply #8November 21, 2006, 08:04:28 pm
« Reply #8 on: November 21, 2006, 08:04:28 pm »
Argument for the other side being a shorter hose yeilds faster response time.
Reply #9November 21, 2006, 08:06:43 pm
« Reply #9 on: November 21, 2006, 08:06:43 pm »
Quote from: 745 turbogreasel
if you have the hose laying around, do a temp setup to the interior for tuning then put it in the bay when ur done and fine tune it case different hose length changes anything
Reply #10November 21, 2006, 08:48:36 pm
« Reply #10 on: November 21, 2006, 08:48:36 pm »
i personally like the hillfolk boost controller... "MORE" hehe!  need to find the pic of the setup!
i think the response time could be tuned with how much of that pressurized air you want the wastegate to actually see... by turning the knob a little bit outward.
Reply #11November 22, 2006, 06:17:07 am
veeman
  • 421
« Reply #11 on: November 22, 2006, 06:17:07 am »
Mine's in the engine bay right around the strut tower.  Not ideal, but I didn't want to run it into the interior.   After the initial tuning (note...drive around with the valve all the way OUT first), you don't really have to touch the valve at all, so it's not a hassle to leave it in there.
81 Caddy TD
83 VW GTI FSP
86 4ktq
Reply #12November 26, 2006, 02:06:11 am
MontanaGTD
  • 230
« Reply #12 on: November 26, 2006, 02:06:11 am »
cheers for all the info! I just need to find one now - it only tends to be the Jap squad who us them in the Uk - making the cheapest ones £200+
MK3 Polo G40 - Sold
Reply #13November 26, 2006, 09:24:18 am
bri957cc
  • 23
« Reply #13 on: November 26, 2006, 09:24:18 am »
Have a look on ebay, manual boost controllers are about £25.
Cheers Bri
Reply #14November 26, 2006, 09:55:32 am
MontanaGTD
  • 230
« Reply #14 on: November 26, 2006, 09:55:32 am »
Thanks for that too - only other ones i've seen are Blitz ones at £229!
MK3 Polo G40 - Sold
