Author Topic: Enigen falure  (Read 5287 times)
November 17, 2006, 12:22:35 am
ISBjornen
  • 36
Enigen falure
« on: November 17, 2006, 12:22:35 am »
Hello
I bught a injection pump for my Golf 1,9TD -96 this summer.
I haven got i working good on my car så we tried it om a friends skoda pick up. its almost the same enigen. the result is god and bad.
we estimate the power to be over 200hp now. and its spining the weils on 1,2,3,4 gear. We dident try the fift.
The bad news is that the enigen brooke down. after about 15 minutes of fu diriving.(not extremly hard) the enigen justa sad STOP. Now we kant move it att all.
Tha boost is about 3-3,5 bar. and the pump is not at its max.
Its sad Vw dident make a better enigen. :) we have 3 new eningens coming in to day so we are going to tear the old one down next week and build a new one.
Kristensen
Reply #1November 17, 2006, 01:19:03 am
Audi80
Enigen falure
« Reply #1 on: November 17, 2006, 01:19:03 am »
What turbo did you use? What did break? Connecting rod? Overheating?
Reply #2November 17, 2006, 06:27:37 am
ISBjornen
  • 36
Enigen falure
« Reply #2 on: November 17, 2006, 06:27:37 am »
the turbo is from a volvo D5. i dont know wath is broken yet but iil find out next week.
connecting rod?
overheating. just o litle. iil give you more info next week. at leask the pump is working...
Kristensen
Reply #3November 17, 2006, 07:37:58 am
MacGyver
  • 245
Enigen falure
« Reply #3 on: November 17, 2006, 07:37:58 am »
You ran 5 times the max boost of the stock motor and tripled the hp and it broke.  Hmmm, yeah it's too bad VW didn't think of preventing that.   :P
LMAO :lol:
On a couple other forums I browse, that's signature material 8)
Reply #4November 17, 2006, 08:01:21 am
BellCityDubber
  • 251
Enigen falure
« Reply #4 on: November 17, 2006, 08:01:21 am »
Quote from: "MacGyver"
LMAO :lol:
You mean the V..... Vo..... Vort......
I can't say it
but those are some impressive numbers for such a short run. I'd like to hear some more once the new engines arrive.
Reply #5November 22, 2006, 02:25:24 pm
Benjamin
  • 485
Enigen falure
« Reply #5 on: November 22, 2006, 02:25:24 pm »
@ISBjornen, any update yet.
Greetz, Benjamin
Must make +250hp
Reply #6November 22, 2006, 03:47:24 pm
smutts
  • 720
    ClackClackClackClackClack
Enigen falure
« Reply #6 on: November 22, 2006, 03:47:24 pm »
3.5 bar, 52psi,  :roll:
Reply #7November 22, 2006, 11:31:17 pm
ISBjornen
  • 36
Enigen falure
« Reply #7 on: November 22, 2006, 11:31:17 pm »
just a smallone. aparently it was a..... that broke i dont know wath its called. it makes the lowest axel in the enigen glide. the axel is the one were the pistons is attaced.
anybody know?
Kristensen
Reply #8November 22, 2006, 11:44:03 pm
Enigen falure
« Reply #8 on: November 22, 2006, 11:44:03 pm »
Quote from: ISBjornen
anybody know?
are you talking about the crank?  a crank bearing failed?? thats all i can think of:
piston is attached to it - piston is connected to the con bone, con bone connected to the... crank bone...  :lol:
makes the lowest axle in the engine glide - sounds to me like a bearing, and by axle, i take it you mean something that turns 360. could there be anything else?   :wink:
Reply #9November 23, 2006, 12:11:47 am
Audi80
Enigen falure
« Reply #9 on: November 23, 2006, 12:11:47 am »
anybody know?
Does this look like it? Or this: connecting rod
Reply #10November 23, 2006, 05:06:28 am
ISBjornen
  • 36
Enigen falure
« Reply #10 on: November 23, 2006, 05:06:28 am »
its the crank bearings that faild. were can i find new ones that is bether then the original?
Kristensen
Reply #11November 23, 2006, 05:31:06 am
QuickTD
  • 1156
Enigen falure
« Reply #11 on: November 23, 2006, 05:31:06 am »
Better crankshaft main bearings are not available.
 The connecting rod bearings from a ASZ (130hp) will fit and are made with a different process and should be better. The shells marked "sputter" should be installed on the top (piston side) of the rod.
Reply #12November 23, 2006, 12:04:18 pm
Chestrockwell
  • 95
Enigen falure
« Reply #12 on: November 23, 2006, 12:04:18 pm »
Wait, I still want to hear about how you got 50psi into an AAZ ( or whatever engine it was)? What injection pump was being used? What turbo? Spinning in 4th?
Reply #13November 28, 2006, 02:33:40 am
ISBjornen
  • 36
Enigen falure
« Reply #13 on: November 28, 2006, 02:33:40 am »
Quote from: Chestrockwell
Its an AAZ 1,9 enigen. the pump is a modified original pump. the "LDA"(I think its called) is modified, 12mm pump head from a VW T4(injector head), the turbo is a schwitzer S1BG(the largest of 3 sizes)
ASZ it an TDI?
Kristensen
Reply #14November 28, 2006, 06:45:15 am
QuickTD
  • 1156
Enigen falure
« Reply #14 on: November 28, 2006, 06:45:15 am »
ASZ it an TDI?
I just rechecked and there might be an error in the old catalog. The new catalog shows the the ASZ the ARL (130 and 150hp) TDI's as having larger bearings. These won't fit your engine.
 The older rotary pump 110hp engines have the "sputter" bearing and a "normal" (not a sintered metal, cracked cap) connecting rod. The engine code for that engine is AHF, those bearings should fit properly and stand up better under hard use.
