Author Topic: How often do you drain the water separator?  (Read 3878 times)
November 16, 2006, 05:29:55 pm
bvolks73
  • 183
« on: November 16, 2006, 05:29:55 pm »
I've had my car for 10 years and have never drained the water separator because the drain broke off and  was plugged with some kind of gas tank repair stuff. Is it really that important? I have another one that's not broken and have been thinking about changing it.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #1November 16, 2006, 07:29:23 pm
Doug
« Reply #1 on: November 16, 2006, 07:29:23 pm »
I'd leave it alone. If it starts to leak, then you get air leaking in, your pump will not be able to draw fuel from the tank. I have bypassed mine on an old Jetta that I was using until recently. The plastic had gone quite brittle developing a steady leak. Just chase the water with an additive now and then plus change the under hood fuel filter every fall.
