Author Topic: Difference 1,6 1,9 ve pump  (Read 2418 times)
November 15, 2006, 06:39:55 am
ISBjornen
  • 36
« on: November 15, 2006, 06:39:55 am »
wath is the diference betven the injector pump om a 1,6 enigen and the 1,9 AZZ.
Can i use a 1,6 pump om my 1,9?
Kristensen
Reply #1December 15, 2006, 02:17:52 am
ISBjornen
  • 36
« Reply #1 on: December 15, 2006, 02:17:52 am »
nobody that can help me?
i cant find any differences
Kristensen
Reply #2December 15, 2006, 02:28:03 am
Audi80
« Reply #2 on: December 15, 2006, 02:28:03 am »
You can use 1,6 pump in 1,9. You might need to use pump bracket and pulley from 1,6 too.
Reply #3December 15, 2006, 06:56:46 am
« Reply #3 on: December 15, 2006, 06:56:46 am »
The "snout" that protrudes past the bracket is considerably longer on the AAZ.  Some had 20 mm pump shafts instead of 17mm.  The camplates have a taller profile.  Some had a joke aneroid pin and no starwheel or aneroid top adjustment.  Also there was the addition of a solenoid for idle timing retard.
Andrew
hmmmm wonder if it would be possible to hook up a makeshift electric cold start system :)  advance the pump an extra .05mm, then run the motor with the idle timing retard when the motor is warm.  run it without when the motor is cold...?
