Author Topic: Are there uprated 1.9TD glow plugs?  (Read 7286 times)
November 08, 2006, 05:10:23 pm
Slave2School
  • 531
« on: November 08, 2006, 05:10:23 pm »
Hi just a question for a friend, is there such a thing as a higher output glow plug for the 1.9TD?  I would have guessed the guys running a lower compression ratio would be running them already if there was, but I had to ask to make sure.
Thanks!
2002 ford focme wagon
Reply #1November 08, 2006, 07:32:01 pm
« Reply #1 on: November 08, 2006, 07:32:01 pm »
you could probably figure out hotter ones, i know at napa i can look at all the different types
Reply #2November 09, 2006, 01:59:18 am
HarryMann
  • 170
« Reply #2 on: November 09, 2006, 01:59:18 am »
Red hot is red hot !
If they are new and in good condition and the battery has full voltage I doubt they can be improved much, maybe just to heat up faster but more current drain and then they'd overheat?
Reply #3November 09, 2006, 03:53:28 am
Slave2School
  • 531
« Reply #3 on: November 09, 2006, 03:53:28 am »
I don't know, the TDI plugs and the PD plugs are both hotter and faster than the older glow plugs so something must have changed.  The TDI plugs are White hot.
Reply #4November 09, 2006, 04:49:10 am
HarryMann
  • 170
« Reply #4 on: November 09, 2006, 04:49:10 am »
Yes white hot!
Maybe smaller gets hotter quicker...
Reply #5November 09, 2006, 04:55:01 am
Slave2School
  • 531
« Reply #5 on: November 09, 2006, 04:55:01 am »
I have no idea.  The PD glow plugs don't take kindly to being dropped, shaken or stirred before installation is all I know (while ours the older stuff seems to be a bit more robust).  Not something I want to deal with.  On another forum I visit a fellow got a free engine replacement due to a plug braking off after installation by the dealer.  Sounds like loads of fun.
If anyone does have a known upgraded replacement part number that would be great I don't have an IDI and my cousin isn't going to know exactly what he's looking for either.
Reply #6November 09, 2006, 06:00:03 am
saurkraut
  • 904
« Reply #6 on: November 09, 2006, 06:00:03 am »
Bosche is probably the best.
Grounds are REALLY IMPORTANT too.  A big fat wire from the negative terminal of the battery, to a trany to block bolt will do wonders for cold starts.  Both the starter and the glow circuit are big current hogs.  Bad grounding with affect both significantly.  Especially because they're both opperating symutainiously on a cold start.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #7November 09, 2006, 08:37:13 am
Slave2School
  • 531
« Reply #7 on: November 09, 2006, 08:37:13 am »
Cool thanks for the tips :)
I recall reading somewhere there are "fast" and "slow" plugs for the older IDI's would there be any advantage to using the fast plugs with the guts used to drive the slow plugs (Which I'm not even sure of how works on the IDI's on the TDI the computer tells the glow plugs how long to go based on several factors).
Reply #8November 09, 2006, 09:03:44 am
saurkraut
  • 904
« Reply #8 on: November 09, 2006, 09:03:44 am »
A slow glow relay with fast plugs will come to grief quite quickly.  The glow plugs will burn out.
Keys to success: 4 good glow plugs, a good relay, clean electrical connections on the glow plugs, glow plug buss bar to harness, glow fuse, and good grounding on the engine.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9November 09, 2006, 09:20:10 am
Slave2School
  • 531
« Reply #9 on: November 09, 2006, 09:20:10 am »
That's what I thought might happen ;)  I guess the TDI plugs are more tolerant to that sort of thing (I've got my glow time/tolerance increased a bit over stock via vag-com as I as having some issues starting in the 5-9C area where my car wasn't activating them at all).  I'll pass the suggestions along :)
Reply #10November 09, 2006, 09:46:57 am
HarryMann
  • 170
« Reply #10 on: November 09, 2006, 09:46:57 am »
Can anyone exoplain briefly them hwo the time thing works with the relay, or is it all done on temperature - can see a timer anywhere? Thanks
Reply #11November 09, 2006, 11:30:24 pm
deepmud
  • 158
« Reply #11 on: November 09, 2006, 11:30:24 pm »
What about the "dual coil" plugs I see on Ebay? Supposed to be a fast heat-up coil that switches to continuous duty after it heats up. Sounds like a great concept.
the 1.9TD/Suzuki w/big tires guy
visit Alaska @ www.alaska4x4network.com
Reply #12November 10, 2006, 03:37:36 am
Slave2School
  • 531
« Reply #12 on: November 10, 2006, 03:37:36 am »
That's exactly the sort of thing he's looking for, now I have to do more searching lol
Reply #13November 10, 2006, 03:46:40 am
Slave2School
  • 531
Reply #14November 10, 2006, 06:31:54 am
saurkraut
  • 904
« Reply #14 on: November 10, 2006, 06:31:54 am »
Well,... Share your results if you go to these plugs.
From my experience, the Bosch plugs work great, if you have all the other glow system components working correctly.
And I sincerely doubt that Bosch would blow off upgrading their product offering if there was truely a break through in glow plug technology:
http://www.boschautoparts.com/Products/DieselParts/Glow%20Plugs
Once these puppies are glowing red hot in the prechamber, if you have compression and fuel, there will be fire in the hole.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
