Author Topic: [Golf Mk2] windshield water-jet  (Read 4018 times)
October 31, 2006, 02:00:02 pm
HP
  • 225
« on: October 31, 2006, 02:00:02 pm »
My windshield washer (I don't know the right name in english..) doesn't work.  The wipers work fine, but when I activate the washer, the thing gives no response! No water, no wipers.
The rear washer is ok, btw  :idea:
I belive there must be some disconnected wire somewhere because this problem just came after my mechanic replaced the heater core radiator, dashboard out and stuff...  :roll:
How shall I fix this?
any help appreciated.
Reply #1November 01, 2006, 03:07:43 pm
« Reply #1 on: November 01, 2006, 03:07:43 pm »
Probably a bad switch. If you remove the steering wheel column trim you'll see all the connectors, one may be loose
Reply #2November 02, 2006, 03:48:05 am
HP
  • 225
« Reply #2 on: November 02, 2006, 03:48:05 am »
Yeah, probably is it. Thanks.
