Author Topic: question about fuels  (Read 6927 times)
October 31, 2006, 01:43:34 pm
A Guy
« on: October 31, 2006, 01:43:34 pm »
I was on the US side in Massena NY to do a P/U and wanted to fill up my 1.9 TD.  This was the first time I had taken my car over.  I was surprised to see two different types of fuel.  One was a low sulfur diesel with a lrge warning on it and the 0ther was kerosene at a much lower price.  i ended up just putting the diesel in but wondered if I could have run the cheper option without any loss in driveability.  can someone chime in here and shed some light on this for me.  Thanks in advance.
Out.
Greg
Reply #1October 31, 2006, 03:49:24 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #1 on: October 31, 2006, 03:49:24 pm »
I believe that the Kerosene dosnt have the lubrication that the diesel fuel has.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #2October 31, 2006, 07:07:40 pm
anarchyx34
« Reply #2 on: October 31, 2006, 07:07:40 pm »
You guys dont have kerosene up there? Kerosene isnt really used for vehicles/engines, but more often for kerosene-fueled heaters and other types of heat generating equipment.
Like one of these things:
A diesel engine will burn it, but like was stated above dosent have the lubricating qualitys (dosent have to). You can mix it with diesel from what I've heard if you have gelling problems in cold weather.
Reply #3October 31, 2006, 07:32:49 pm
sethyboy85
  • 284
« Reply #3 on: October 31, 2006, 07:32:49 pm »
That and if a cop/proper authorities with nothing to do saw you filling up you might spend a night in jail till they clear up the confusion after trying to explain to you that it's a $30k fine for running NON road taxed fuels (most kero ain't taxed) in the US
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #4November 01, 2006, 06:36:10 am
clbanman
  • 705
    Cambridge, Ontario
Running on kerosene
« Reply #4 on: November 01, 2006, 06:36:10 am »
Quote from: Kudagra
We have a kerosene option on our trucks with Cummins engine, and it involves changing out the injection pump. That's the only difference, and with that pump it's considered a dual fuel engine. I am not familiar with the internals on the pump, but am assuming that the differences would be seals, etc. to make up for the lubrication issue. Now how much difference is there between kerosene and the ultra low sulfur diesel?
Calvin
91 VW Golf 1.6NA 5spd
Reply #5November 01, 2006, 11:21:08 am
« Reply #5 on: November 01, 2006, 11:21:08 am »
if you don't mind mixing your fuel, i'd go with kerosene and a lubrication additive.   you would need to religiously add the lubrication additive though.. or suffer the consequences!
Reply #6November 01, 2006, 05:25:14 pm
sethyboy85
  • 284
« Reply #6 on: November 01, 2006, 05:25:14 pm »
In the very near future NONE all Diesel, #2/red dye Kero will be 15ppm
at least in the big state of US
Reply #7November 02, 2006, 07:08:19 am
clbanman
  • 705
    Cambridge, Ontario
low sulfur fuel
« Reply #7 on: November 02, 2006, 07:08:19 am »
On a related note, I was going through some of our service bulletins, and we sent one out stating that low sulfur diesel fuel has up to 15% lower specific energy content than regular diesel.  Now this was issued in 1991, so I don't know if there are hard scientific numbers to back this up or if it was a CYA just in case there were problems or issues with the newer fuels.
Calvin
Reply #8November 04, 2006, 09:54:13 am
A Guy
« Reply #8 on: November 04, 2006, 09:54:13 am »
So don't use straight kerosene.  We do have kerosene up here but I've never seen it at the gas station.  I was just shocked at the diff in price.  If I had half a tank of diesel could I fill up w/kerosene without any issues.
Thanks to all those who chimed in.
Out.
Reply #9November 05, 2006, 04:02:34 pm
Doug
HALF A TANK OF DIESEL?
« Reply #9 on: November 05, 2006, 04:02:34 pm »
Why do you want to risk your pump lubrication for a couple of bucks saved on kerosene?
Reply #10November 06, 2006, 06:54:19 pm
« Reply #10 on: November 06, 2006, 06:54:19 pm »
kerosene isn't the same as diesel anyways, it's more than just a lack of lubrication, i was under the impression that the new diesel had more enery content.  i dunno about all the griping about ulsd killing pumps though, it has new "safe" additives in it for lubrication and pump seals and all that ish,  they can't/won't just change to crap that will kill all our cars.
Reply #11November 06, 2006, 06:54:48 pm
« Reply #11 on: November 06, 2006, 06:54:48 pm »
oh yeah and the difference in price is the lack of road tax.
Reply #12November 08, 2006, 02:39:38 pm
jantd
  • 38
« Reply #12 on: November 08, 2006, 02:39:38 pm »
Hi guys,
Just read an interesting article about differnce between traditional diesel and new low sulfer one, the power was tested on a 2.0tdi 140HP VW engine.5 different diesel brands were tested, of which shell and bp.Result: for ALL brands, the tradicional diesel delivers between 0.5 and 2 BHP MORE than the new generation diesels,(which cost 5cents more! )If you know that bp advertises 8.2 % more horse power with their new generation diesel....interesting .
Reply #13November 08, 2006, 03:45:16 pm
Benjamin
  • 485
« Reply #13 on: November 08, 2006, 03:45:16 pm »
it will kill your pump like said before
when we need to go to the technical control in Belgium, aka aircare, just put some kerosene in the car, you will see very good result, after this test, i go to the pump and i fill the car full, so i dont need to drive on straight diesel.
when you have to much smoke and you need to go to the aircare, its a smart tip.  :wink:
Greetz, Benjamin
Must make +250hp
