VWDiesel Blog
Facebook Group
VWD on Twitter
Nothing like a good DIY Top end rebuild
Topic: Nothing like a good DIY Top end rebuild (Read 4936 times)
October 20, 2006, 07:40:43 pm
October 20, 2006, 07:40:43 pm »
Write up covers:
- Installing valves
- Installing valve springs
- Installing valve seals
- Installing cam / bearings
- Adjusting valves
- Installing injectors
- Installing glow plugs
- Installing valve cover studs (rubber gasket upgrade)
- Installing exhaust manifold studs
http://www.hasengeeks.com/projects.php?page=cylinder_head
Found here
http://vwpickups.com/forum/viewtopic.php?t=29
apparently they've been hacked. But you can still access the whole forum by using the "jump to" in the bottom right
October 20, 2006, 11:20:58 pm
Darkness_is_spreading
October 20, 2006, 11:20:58 pm »
Awesome, now I can reference against this for later use......
92 Jetta 1.6 T (Sleepin)
October 22, 2006, 04:04:28 pm
HarryMann
October 22, 2006, 04:04:28 pm »
.. and if you're in any doubt, valve 'keepers' are collets as in a 'collet' chuck, if you're reading on this side of the Atlantic.
Good and exhaustive writeup there, but it would take me most of that 2 hours to cut 8 valves in properly
October 24, 2006, 07:10:27 pm
October 24, 2006, 07:10:27 pm »
for better pictures, copy the image location top a new window and remove the .thumb
