Author Topic: MBC boost source  (Read 1808 times)
October 20, 2006, 01:41:04 pm
92A2VWJTD
MBC boost source
« on: October 20, 2006, 01:41:04 pm »
I just recieved a simple ball-and-spring MBC in the mail. With the excitement of enjoying a long awaited performance increase, I also find myself now wondering about my original idea to jack it in directly off the compressor inline with the short stretch of tube leading to the WG (Garrett). I got to thinking, and wondered if maybe it wouldn't be better to use the intake manifold as a boost source, then on to the WG, while just plugging up the outlet from the compressor? I am by no means an expert on turbo systems, but have heard that by using the manifold as your source there may be spikes but there will be less lag (a good thing with the Garrett). Directly off the compressor will yield more lag, no spikes, and possible performance changes relative to ambient Wx changes. Is any of this true for the 1.6TD? Does anyone have experience with both methods of connecting an MBC?
Thanks.
Reply #1October 20, 2006, 03:57:06 pm
g-spec
  • 289
MBC boost source
« Reply #1 on: October 20, 2006, 03:57:06 pm »
I would like to know aswell as i will be installing a mbc sometime in the near future.....
free bump
Reply #2October 20, 2006, 04:55:51 pm
macsdub
  • 165
MBC boost source
« Reply #2 on: October 20, 2006, 04:55:51 pm »
i cant vote 2x :cry:
i had a garret,and now a kkk
i prefered the garret btw,more overall power :twisted:
most of the time this is hilfolk'r... ive forgotten my password
Reply #3October 20, 2006, 05:38:48 pm
DVST8R
  • 535
MBC boost source
« Reply #3 on: October 20, 2006, 05:38:48 pm »
With the style of mbc that I use (pressure switch and air solnoid) I always run it from the manifold pressure, as when I run it from the turbo it is too jumpy +/- 5psi, when I run it from the mainfold it is steady +/- < 0.5psi. I have run this on KKK and on the stock Garrett, as well as the GT seires, ect...
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #4October 20, 2006, 05:46:07 pm
zagarus
  • 619
MBC boost source
« Reply #4 on: October 20, 2006, 05:46:07 pm »
i get smooth response from the inlet on my garrett.  I can even tell if im pushing out 0.5 psi, and no spiking or jumping, its uber accurate.
Reply #5October 24, 2006, 12:02:23 pm
foxracer1
  • 991
MBC boost source
« Reply #5 on: October 24, 2006, 12:02:23 pm »
So if the compressor port is creating spikes wouldn't it be better to hook the boost line up to the manifold so the wastegate doesn't see these spikes?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
