Author Topic: intermittent low coolant  (Read 4399 times)
Reply #15October 19, 2006, 08:31:51 pm
LeeG
  • 401
« Reply #15 on: October 19, 2006, 08:31:51 pm »
the place that did the thermostat should give you a free coolant pressure test.  If you told them about coolant loss and temp problems they should have done one in the first place.  It should only take them a few minutes, so pressure them for it (another pun!) if needed.  tell them its using a lot more coolant since they worked on it.
'97 Passat TDI
