Author Topic: Propane injection.  (Read 9506 times)
Reply #15October 28, 2006, 09:31:18 am
Zeitgeist
  • 90
    Rule Cascadia
Propane injection.
« Reply #15 on: October 28, 2006, 09:31:18 am »
Here's a kit that (sort of) injects liquid propane:
http://www.delucafuelproducts.com/
It's vacuum activated, but has a manually adjusted flow metering system.  It converts the liquid to vapor, so it's probably not what you're trying to locate.
The Powershot is nice, but when new, it's too expensive for most DIY types (like me).  I picked it up for less than half price, otherwise I'd still be looking for another solution.
BTW:  Have any of you tried nitrous, yet?
'87 300TD (OM606)
'90 300D (OM602)
'89 Vanagon Bluestar (ALH)
'01 EV Weekender (AXK)
'04 Passat Variant (BHW)
Reply #16March 28, 2011, 07:31:58 pm
Zeitgeist
  • 90
    Rule Cascadia
Re: Propane injection.
« Reply #16 on: March 28, 2011, 07:31:58 pm »
bump:
Any new info on this topic since we last explored this in 2006?
'87 300TD (OM606)
'90 300D (OM602)
Reply #17March 28, 2011, 07:50:38 pm
trav1856
  • 230
« Reply #17 on: March 28, 2011, 07:50:38 pm »
I would go with water/methanol injection way before propane.  You are going to get more power and it drops your exhaust gas temps.   Snow performance makes great kits.  I am going to be putting a kit on my 93 in the new year.
What about an HHO bubbler? The end result is water, which will both increase expansion on the power stroke, and lower EGT's.
1981 Rabbit Diesel
1981 Cabriolet
Reply #18March 28, 2011, 08:13:48 pm
foxracer1
  • 991
« Reply #18 on: March 28, 2011, 08:13:48 pm »
I had a valve failure in my 1.6td and have since gone TDI. Well currently in the swap stage. I still plan to look into water and propane injection.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #19March 28, 2011, 11:02:07 pm
blackdogvan
  • 574
« Reply #19 on: March 28, 2011, 11:02:07 pm »
water emulsion fuel makes huge sense in a mine.
http://www.energy.wsu.edu/ftp-ep/pubs/renewables/PuriNoxl.pdf
1991 Vanagon 1.9 mTDI
Reply #20March 29, 2011, 09:26:12 am
« Reply #20 on: March 29, 2011, 09:26:12 am »
TDI is much more friendly to propane injection, being that there is no pre-chamber to grenade the engine if you shoot too much propane..
