Author Topic: Need advice on stretch bolt torque (1992 Jetta)  (Read 2201 times)
October 16, 2006, 04:10:30 pm
larry104
  • 200
« on: October 16, 2006, 04:10:30 pm »
I tightened the head bolts in the proper sequence to the recommended torque using this procedure:
30 ft-lb
44 ft-lb
additional 1/2 turn
It says now to warm up the motor, then do an additional 1/4 turn in sequence.  Is this really necessary? Has anyone here not done it? What happened?
Reply #1October 16, 2006, 07:00:05 pm
SMOKEYDUB
  • 630
« Reply #1 on: October 16, 2006, 07:00:05 pm »
it is very necessary and will probably loose a head gasket in the near future
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2October 16, 2006, 07:09:57 pm
larry104
  • 200
« Reply #2 on: October 16, 2006, 07:09:57 pm »
Quote from: SMOKEYDUB
I only started it once and haven't driven it. I'll do the 1/4 turn before I drive it. Thank you.
Reply #3October 16, 2006, 07:12:30 pm
« Reply #3 on: October 16, 2006, 07:12:30 pm »
warm it up to exactly what the bentley says to and go form there. The re-torquing 1000 kms later is the contraversial one
Reply #4October 16, 2006, 08:58:04 pm
macsdub
  • 165
« Reply #4 on: October 16, 2006, 08:58:04 pm »
yea those bolts are so stretched by then....
a metal head gasket is the reason for part of the controversy i guess
i havent  checked mine yet
but im runnin head studs and  its a tdi-m
i did check em after a few days and i got like no movement,but maybe it wouldnt hurt for me to check mine,,,,,,,,,,,
 :lol:
most of the time this is hilfolk'r... ive forgotten my password
