Author Topic: Fan upgrade  (Read 4650 times)
October 07, 2006, 08:38:07 pm
Powjetta
  • 152
    San Diego CA
Fan upgrade
« on: October 07, 2006, 08:38:07 pm »
I have a dual fan from a passat to install on my jetta to help with slow speed air flow.  It looks like it has 3 speeds while my system has 2.  I was going to hook up 2 of them, has anyone done this before?  Should I use low and high or 2nd and high?
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #1October 08, 2006, 04:23:52 pm
Fan upgrade
« Reply #1 on: October 08, 2006, 04:23:52 pm »
the 1st fan speed should have  a resistor on it.. its for a/c.  Don't worry about connecting it.
Reply #2October 09, 2006, 04:27:11 pm
Powjetta
  • 152
    San Diego CA
Fan upgrade
« Reply #2 on: October 09, 2006, 04:27:11 pm »
I have hooked up high and low speed and it works.  It really moves air and covers all but 2" on the alternator side of the radiator.  I have blown two fuses so far does anybody know of a possible current drain or why this may be?  I have implemented Roger Browns trick of the manual switch on the thermoswitch to control it and and when I close that switch it burns the fuse.  His instructions are for the old 1 speed fan so I am pushing into areas that I don't know how it works together.
Reply #3October 09, 2006, 09:30:55 pm
Fan upgrade
« Reply #3 on: October 09, 2006, 09:30:55 pm »
hmmm... how many prongs does your thermoswitch have? if it has 3 then only jump the fast one for your switch.  if you jump both it will blow the fuse for sure.
i was thinking of getting one of the dual fan setups... i really like the fact that it moves air around the whole radiator... good for summer + a/c :)
Reply #4October 10, 2006, 03:57:51 pm
Powjetta
  • 152
    San Diego CA
Fan upgrade
« Reply #4 on: October 10, 2006, 03:57:51 pm »
My thermoswitch has three wires for the two speeds.  I think I'll put in a relay for the low speed and put a switch on that setting.  The manual tells you how to check the fan operation by shorting the red wire on the thermoswitch to the other wires.  The dual fan has a strong current draw on high speed.  So far the 40 amp fuse has held but I dont want to use it, it makes the battery connections hot.
Reply #5October 13, 2006, 09:03:51 am
Fan upgrade
« Reply #5 on: October 13, 2006, 09:03:51 am »
the high speed mode should not be on for too long... maybe 2 mins at most.  sometimes it can stay on longer in hot traffic. :(
I tested my fan to make sure it was working by jumping the connections on the thermoswitch... i may be replacing my thermoswitch sometime soon though :)
