Author Topic: making my 1.9td faster  (Read 5440 times)
September 30, 2006, 06:51:36 pm
kidkoala
  • 34
« on: September 30, 2006, 06:51:36 pm »
hey folks - i'm just about to start on the next step of making my car 'faster', but i'm unsure as to how i might achieve the step listed below
Quote from: VWRacer
2. Now, to disconnect the connector #4 and to find a means of connecting the selenoid which is below of this connector #4 on the same wire as the connector #3 (fuel cut-off selenoid). You can let the connector #4 hang, it is now useless.
This modification prevents the pump from "delaying" the timing to reduce the Nox (polution) It is necessary that this selenoid(#4) is activated (12v) with each time the engine is ignited to keep the advanced timing even with low RPM.
how might i be able to connect the selenoid to connector #3?
anyone done this that could shed some light?
many thanks!
Reply #1September 30, 2006, 08:47:33 pm
ricosuave
  • 244
« Reply #1 on: September 30, 2006, 08:47:33 pm »
you would remove #4 connector, then take another piece of wire with a similar end and splice it into the #3 line somewhere, and run the new wire over to where #4 would go...
Reply #2September 30, 2006, 09:12:40 pm
coke
  • 254
« Reply #2 on: September 30, 2006, 09:12:40 pm »
Is the solenoid in the red circle pictured here the one that needs to have a constant 12v feed to it? And this solenoid is a timing advance of some sort?
I dont think this solenoid works on my car and I've had a hell of a time starting it when warm, but if I advance the timing with the cold start lever it works great. What does it get its feed from? A temperature sender?
Reply #3September 30, 2006, 10:54:24 pm
kidkoala
  • 34
« Reply #3 on: September 30, 2006, 10:54:24 pm »
Quote from: ricosuave
could i snip #4, splice it to #3, cap the leftover #4 wires?
Reply #4September 30, 2006, 11:00:00 pm
coke
  • 254
« Reply #4 on: September 30, 2006, 11:00:00 pm »
Why dont you just leave enough wire of the #4 connector, cut it, put a round connector on it and hook it to the fuel solenoid on the pump?
Reply #5October 01, 2006, 07:57:57 am
« Reply #5 on: October 01, 2006, 07:57:57 am »
no the solenoid in the picture is not the one tha tneeds a constant 12v, the one that needs a constant 12v is the one under the lda, it looks almost like a oil pressure or water temp sending unit or something
Reply #6October 01, 2006, 09:29:21 am
coke
  • 254
« Reply #6 on: October 01, 2006, 09:29:21 am »
The solenoid your referring to would be the fuel shutoff solenoid and that has 12v anyways, because if it didn't, your car wouldn't be running. #4 in the picture posted above I believe is what I have circled in mine, and that article is saying #4 has to have a constant 12v+ as well as the fuel shutoff solenoid, labled as #3.
Reply #7October 01, 2006, 11:19:25 am
Chestrockwell
  • 95
« Reply #7 on: October 01, 2006, 11:19:25 am »
The constant power thing will do very little if anything to the performance. It is a minor advance solenoid that decreases fueling at low manifold pressure. I noticed nothing when I did this on my car.
Reply #8October 01, 2006, 12:21:56 pm
kidkoala
  • 34
« Reply #8 on: October 01, 2006, 12:21:56 pm »
Quote from: Chestrockwell
so this step is not necessary to adjust the fuel? i could just skip it?
Reply #9October 02, 2006, 06:31:32 pm
kidkoala
  • 34
« Reply #9 on: October 02, 2006, 06:31:32 pm »
anyone?
Reply #10October 02, 2006, 06:41:21 pm
coke
  • 254
« Reply #10 on: October 02, 2006, 06:41:21 pm »
Seemed to help my car, I'd do it. Takes about 10 minutes max.
Reply #11October 02, 2006, 07:11:15 pm
Chestrockwell
  • 95
« Reply #11 on: October 02, 2006, 07:11:15 pm »
I was just talking about providing constant power to the advance unit on the side of the IP. I don't know if the advancer is the same on a 1.6. As for fueling and turbo adjustment, they will definately change the performance of your engine.
Reply #12October 03, 2006, 10:01:13 am
kidkoala
  • 34
« Reply #12 on: October 03, 2006, 10:01:13 am »
Quote from: coke
so i guess i go back to my original posting, how do i connect these two?
Reply #13October 04, 2006, 07:02:46 pm
kidkoala
  • 34
« Reply #13 on: October 04, 2006, 07:02:46 pm »
anyone help with this simple task? i don't want to screw things up, just looking for advice from people that have done this before.
can i simply cut #4 and splice it to #3?
Reply #14October 04, 2006, 07:57:50 pm
andy2
« Reply #14 on: October 04, 2006, 07:57:50 pm »
Yes you can simply cut #4 and splice into #3,just insulate or cover up the remaining #4 wire so it does'nt short out on things.
