Author Topic: cold start lever wont advance pump  (Read 3455 times)
September 21, 2006, 12:42:24 pm
cadmo
  • 22
« on: September 21, 2006, 12:42:24 pm »
As the topic says my cold start lever does nothing.  The cable's  not broke and moves freely as well the lever on the pump moves easely, but when it moves nothing happens, as well idle screw that is attached some how will not lower or raise the idle.
Does anyone have any ideas on what could be wrong?
Reply #1September 21, 2006, 02:49:20 pm
cadmo
  • 22
« Reply #1 on: September 21, 2006, 02:49:20 pm »
interesting
im going to guess that the piston is stuck, because it idles at 700-750 rpm and is harder to start than normal (needs throotle and once started its choppy for about 30 seconds)
any more thoughts?
Reply #2September 21, 2006, 03:36:07 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
« Reply #2 on: September 21, 2006, 03:36:07 pm »
Ignore RPM...There are pumps that don't raise RPM, they just advance timing....
Excuse me on my bad English
Reply #3September 21, 2006, 07:45:04 pm
mbr
  • 31
« Reply #3 on: September 21, 2006, 07:45:04 pm »
Mine did the same thing. The cable wasn't adjusted correctly.
Ben Roubin
Reply #4September 21, 2006, 09:03:21 pm
« Reply #4 on: September 21, 2006, 09:03:21 pm »
there should be a cold start idle advance screw on the pump.
