TDI Engine -General Info
cam
Topic: cam (Read 5407 times)
September 14, 2006, 02:48:54 pm
snakemaster
cam
September 14, 2006, 02:48:54 pm »
would it be worth fitting a cam shaft from a 1.8 gti 8v gas engine to a TDI or would there be valves bent :oops:
Glenmorangie single highland malt
September 14, 2006, 02:53:12 pm
935racer
cam
September 14, 2006, 02:53:12 pm »
Valves will bend and the sprocket does not fit. I have TDI performance camshafts available. Pm me.
September 14, 2006, 03:00:08 pm
snakemaster
cam
September 14, 2006, 03:00:08 pm »
going to rebild my head with std stuff , and when i get it going good i mite up grade , need to get my pump sorted out and then tips , and then go from there
September 14, 2006, 05:45:24 pm
DVST8R
cam
September 14, 2006, 05:45:24 pm »
Tdi-rs reported good gains with the 8v GTI cam, however he had to modify both the cam to fit the sproket and had to fly cut the pistons for clearance. It's easier to just get one from PP.
The Brett of the board...
The Dark Side of Beauty.
[/i]
September 15, 2006, 09:02:50 am
greggearhead
cam
September 15, 2006, 09:02:50 am »
Hey 935 - what are the gains with your cams again? Specifically HP, faster spoolup, and lower EGTs in what amounts?
Thanks.
Caddy (TD Project), Caddy 1.6D, etc etc.
Snow Performance Water-Methanol Injection
September 16, 2006, 11:04:30 am
935racer
cam
September 16, 2006, 11:04:30 am »
It all depends on fuel, you could see egts only drop 50 degrees or you could see them drop 200 degrees if you are over fueled, the cam could give you 3WHP or 20-30WHP.
September 18, 2006, 08:15:28 pm
macsdub
cam
September 18, 2006, 08:15:28 pm »
this has probably been discussed before but how about this?
would a hydro 1.6td cam be any different than the cam in my ahu tdi??
i thought the tdi engines had very low lift compared to the earlier idi engines :?:
most of the time this is hilfolk'r... ive forgotten my password
September 19, 2006, 03:32:06 pm
snakemaster
cam
September 19, 2006, 03:32:06 pm »
any thing is poss how about fitting a 16v head of a gti to a tdi with difrant pistons to rase c.r and the cut outs for the valves and some adapter to get the injectors in :lol: that be some cool looking tdi
and may go well to
September 19, 2006, 06:09:45 pm
935racer
cam
September 19, 2006, 06:09:45 pm »
No a gas vw 16 valve head will not fit, even with intense machine work.
cam
