Author Topic: Oil in LDA  (Read 4249 times)
August 30, 2006, 12:21:40 pm
veeman
  • 421
Oil in LDA
« on: August 30, 2006, 12:21:40 pm »
I took the cover off my 1.6TD pump last night to look at the boost pin and star wheel and I noticed there was about two-three tablespoons of engine oil on top of the diaphragm.
Obviously,  it's coming from the boost line from the intake elbow after the turbo, but I'm not sure if that's normal or not...  FWIW, I've driven it for around 16k miles without opening it up and the turbo was rebuilt recently...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #1August 30, 2006, 12:38:55 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
Oil in LDA
« Reply #1 on: August 30, 2006, 12:38:55 pm »
I did the same thing today, and also had oil on my diaphragm, not that much,  but still noticeable....
But my K14 leaks oil on the compressor side, so my guess is that that's source of my oily diaphragm...
Excuse me on my bad English
Reply #2August 30, 2006, 02:02:29 pm
Oil in LDA
« Reply #2 on: August 30, 2006, 02:02:29 pm »
i get that too, i think alot of it is because of how the crank case vent dumps right into the turbo, that gets oil all through the intake tract, i've actually noticed small bits of oil at my boost gauge. i think this is pretty normal to be honest...  althought i definetly plan on moving the crank ven to dump into a bottle or on to the ground
Reply #3August 30, 2006, 04:09:49 pm
SMOKEYDUB
  • 630
Oil in LDA
« Reply #3 on: August 30, 2006, 04:09:49 pm »
if you look at the lda it has a very good seal i dont think that the oil would go through the rubber. if it was ontop probably but i had oil on the pin side and never figured out what it was. i wouldnt worry about it. maybe someone put a bit of oil in it for longevity because its constantly moving. just my 2 cents.
jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
