Author Topic: How can I install a tach on my 1.6TD?  (Read 4755 times)
August 29, 2006, 10:09:28 pm
Earwig225
  • 56
« on: August 29, 2006, 10:09:28 pm »
I am putting a 1.6TD into my 1980 truck and would like to add a tach. There is no ignition system so how would a tach be installed? Thanks
Reply #1August 30, 2006, 03:33:09 am
« Reply #1 on: August 30, 2006, 03:33:09 am »
through the W terminal on the alternator.  Do a search on here, there are pictures showing where it is located.
Reply #2August 30, 2006, 09:51:33 am
  • 1156
    • Malone Tuning Ltd.
« Reply #2 on: August 30, 2006, 09:51:33 am »
Moved to Troubleshooting. The IDI Engine forum is for power enhancements related discussion only.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #3August 30, 2006, 12:12:53 pm
veeman
  • 421
« Reply #3 on: August 30, 2006, 12:12:53 pm »
If you don't have the alternator with the W terminal, you can also use the optical signal pickup method described here:
http://www.4crawler.com/Diesel/CheapTricks/Tachometer/index.shtml
I've got  his kit, but I'm waiting for a friend to solder it up for me...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #4August 30, 2006, 12:43:40 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
« Reply #4 on: August 30, 2006, 12:43:40 pm »
If the alternator is from TD, then my guess is that it has W terminal and that it is connected to fuse box...Only thing to do is to wire the fuse box and tach...
That kind of setup for tach was on my '91 ECO Golf...
Excuse me on my bad English
Reply #5August 30, 2006, 01:40:31 pm
saurkraut
  • 904
« Reply #5 on: August 30, 2006, 01:40:31 pm »
If you use roger's optical set up, concider putting the target wheel on the cam sprocket.
I was going to put his tach kit on when I changed my pump, but you can't tighten the pump nut(s) behind the sprocket with the target on.  And i'm not too keen on doing the pump timing, knocking off the sprocket, tightening down the pump and putting the sprocket back on.
i have to cut a new aluminum disk to fit the cam sprocket cause I had to trash the one in the kit taking it off the pump sprocket.  It won't fit the cam sprocket either as the hub diameter on the cam sprocket is bigger.
its a nice set up, but if your in the habbit of putzing with injection pump, your out of luck.
Brought it to Roger's attention, don't know if he is going to do anything about it.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
