Author Topic: Jingle Bell Squeak  (Read 3714 times)
August 29, 2006, 03:12:01 pm
Kantdrive55
  • 65
    • http://www.dieselperformance.com
Jingle Bell Squeak
« on: August 29, 2006, 03:12:01 pm »
My 1.9 has started to make a squeak from under the timing belt cover.  Only when it is warm and it sounds like some one has those jingle bells you hear at christmas time.  Yah I know it is a bad description.  Can the tensioner cause this?  I know I am going to have to do the belt and upgrade the keyway at the same time.  Any input would be helpful.
1993 TD Jetta
Cold air intake,pump tweaked,2.5" exhaust and more to come.
Reply #1August 30, 2006, 10:32:59 pm
LeeG
  • 401
Jingle Bell Squeak
« Reply #1 on: August 30, 2006, 10:32:59 pm »
My 1.6TD sounded like that when the 2 halves of the tensioner seperated at the spot welds.  Noise was the inner piece rattling around.  I woudnt drive it far until you know what that noise is!  Getting the timing cover off is only a couple minutes work.
'97 Passat TDI
