Author Topic: Exhaust manifold torque specs  (Read 20905 times)
September 25, 2004, 01:11:04 pm
89VWdieselGolf
« on: September 25, 2004, 01:11:04 pm »
i bought new gaskets for my 1.6 N/A diesel because of an exhaust leak...what should i torque them to?
thanks, Jeff
Reply #1September 26, 2004, 08:43:33 am
racer_x
  • 123
Re: Exhaust manifold torque specs
« Reply #1 on: September 26, 2004, 08:43:33 am »
According to Bentley:
Quote from: "Bentley"
Exhaust manifold to cylinder head . . . . . . . . 25 NM (18 ft. lb.)
Reply #2September 26, 2004, 01:12:46 pm
89VWdieselGolf
« Reply #2 on: September 26, 2004, 01:12:46 pm »
perfect! thanks :D
Reply #3October 14, 2012, 04:11:59 pm
TurboJ
  • 661
« Reply #3 on: October 14, 2012, 04:11:59 pm »
Yes, this is an ancient thread, but the question is very valid.
I just fit my exhaust manifold today, and 25 Nm feels incredibly  little.
I have OE copper nuts, and at 25 Nm it feels like they're barely on.
People: what are your experiences and suggestions?
I have a bigger than standard turbo there too, along with a separate waste gate, which adds a lot of extra weight to be supported bu those little copper nuts...
Jetta II 1.6 TD 'Project 200'
Reply #4October 14, 2012, 05:01:18 pm
« Reply #4 on: October 14, 2012, 05:01:18 pm »
Add a brace from elsewhere, or face broken studs.
I've never had a backing out problem with the OE fasteners @18lb.
Just make sure the threads are nice n clean first.
Reply #5October 14, 2012, 06:24:22 pm
« Reply #5 on: October 14, 2012, 06:24:22 pm »
I honestly never torqued mine. I feel bad, like I should be over on the hillbilly forum saying this. I just use my 1/4" drive rachet and get them tight. It is an 8mm stud so it will take more than 18ft/lbs, but it is in an aluminum head. Hope all goes well for you.
Reply #6October 14, 2012, 07:05:02 pm
« Reply #6 on: October 14, 2012, 07:05:02 pm »
I always torque to 18 ft lbs with the proper nuts and the proper extra-thick washers, but add a triangulating brake to the block with any custom turbo install.
Reply #7October 15, 2012, 12:56:38 pm
TurboJ
  • 661
« Reply #7 on: October 15, 2012, 12:56:38 pm »
OK, thanks, guys!  The 25 Nm just seemed like the nuts would almost fall off...
My plan was from the beginning to build some serious braces for the manifold, turbo, DP and wastegate.
I guess I should be fine then.
And yes, I am using the T2 Transporter Diesel thick washers.
Reply #8October 15, 2012, 01:24:23 pm
« Reply #8 on: October 15, 2012, 01:24:23 pm »
I would also mention that you don't want to over-brace the exhaust either.  Doing so can lead to stress cracks from expansion/contraction from heat cycles.
Reply #9October 15, 2012, 04:16:22 pm
TurboJ
  • 661
« Reply #9 on: October 15, 2012, 04:16:22 pm »
I will be using ball joints in every mounting point of the braces.
Reply #10October 15, 2012, 05:14:40 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #10 on: October 15, 2012, 05:14:40 pm »
Thats what I usually do aswell :-)
I thought this WAS the hillbilly forum????
'91 Golf Cabrio 1.9TD
Reply #11October 15, 2012, 06:56:26 pm
« Reply #11 on: October 15, 2012, 06:56:26 pm »
Nope, the hillbilly forum has a few cross overs here. I am probably just a fuzz more refined than the average hillbilly, but the other diesel forum is full of them. I would go into detail but there are too many here and some may get internet hurt.
Reply #12October 15, 2012, 09:38:38 pm
DanV990
  • 20
« Reply #12 on: October 15, 2012, 09:38:38 pm »
... I just use my 1/4" drive rachet and get them tight. It is an 8mm stud so it will take more than 18ft/lbs, but it is in an aluminum head...
I did the same thing. I put an engine from a NA MKI 1983 Rabbit in my 1992 ECOdiesel in August and I just used a 1/4 ratchet and tightened the exhaust manifold bolts until I felt they were just gutentight. They've been good (no leaks, loose bolts, or broken studs) for the last 3,400 miles.
« Last Edit: October 15, 2012, 09:40:42 pm by DanV990 »
