Author Topic: Oil pressure sender extender  (Read 3572 times)
August 23, 2006, 10:40:19 am
stewardc
« on: August 23, 2006, 10:40:19 am »
I've installed an oil pressure gauge in my Caddy but the much larger sender will not install because of the turbo oil feedline. Does anyone have an extender that would move the sender beyond the oil feedline that they'd like to part with?
Reply #1August 23, 2006, 12:38:45 pm
bert
  • 423
« Reply #1 on: August 23, 2006, 12:38:45 pm »
Hi,i used a brake flexi hose,will cope with oil pressure no problem,and wont get too hot as no oil actually runs through it,i have done this for 4 years no leaks  :wink:
Bert
Reply #2August 24, 2006, 05:25:21 am
stewardc
« Reply #2 on: August 24, 2006, 05:25:21 am »
Heeeelllllppppp :?
Reply #3August 24, 2006, 06:59:30 am
veeman
  • 421
« Reply #3 on: August 24, 2006, 06:59:30 am »
Hmmm... What about something like this? It says it's for Type 4 aircooleds, but I believe the threads are the same.
http://www.germansupply.com/home/customer/product.php?productid=16240&cat=340&page=1
Back when I was looking to run two senders, I found this one as well:
http://www.germansupply.com/home/customer/product.php?productid=16853&cat=340&page=1
That one might not clear the oil line in your engine...
Also, there's another company that sells a similar kit for watercooled VW's, allowing them to run several gauge senders.  Edit:  I think this is it:
http://www.42draftdesigns.com/product/42004.htm
or a complete listing here at the bottom of the page:
http://www.42draftdesigns.com/vdo.htm
Maybe something there will help...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #4August 24, 2006, 10:24:30 am
stewardc
« Reply #4 on: August 24, 2006, 10:24:30 am »
That does it. MANY thanks !!!
Reply #5August 24, 2006, 10:38:17 am
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
Re: Oil pressure sender extender
« Reply #5 on: August 24, 2006, 10:38:17 am »
Quote from: stewardc
I used an Audi 5000 turbo diesel part on my 1.6 (now 1.9)
p/n 035 103 717 and 035 103 715
The picture shows an oil temp sender and a pressure switch, I now have a pressure switch and a pressure sender for a 10 bar guage installed in it.
Drew
Reply #6August 24, 2006, 12:21:30 pm
veeman
  • 421
« Reply #6 on: August 24, 2006, 12:21:30 pm »
Nice move... I think the early Coupe GT's (80-84) and some of the early 4000's had that fitting as well.  Driver's side of the block...
81 Caddy TD
83 VW GTI FSP
86 4ktq
