Author Topic: Manifolds  (Read 16934 times)
Reply #15August 24, 2006, 11:14:16 am
DVST8R
  • 535
Manifolds
« Reply #15 on: August 24, 2006, 11:14:16 am »
I'll take a shot at this for dave (though he probably has other reason's) His Custom manifolds are made out of steel, this is due to, after extensive search's, not being able to find good quailty aluminum mandrel bends. So in his case it is for corrosion resistance as well as heat resistance as aluminum disapates heat naturally much better then steel. Personally I will run a reat shield as well as coating when I go to his manifolds in my winter buildup.  :wink:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #16August 24, 2006, 11:53:40 am
935racer
Manifolds
« Reply #16 on: August 24, 2006, 11:53:40 am »
Quote from: libbybapa
Dave, why coat the intake manifold?  Wouldn't a heatshield between exhaust and intake manifold be as effective and less expensive?  Perhpas not for the lazy.   :D
Andrew
A heatshield the stock manifolds is plenty adequete, but there is just no reasonable way make a heatshield fit with my tubular manifolds. I am header        wrapping the exhaust manifolds along with the ceramic coating. You can actually grab one of the runners with your bare hand while its running and not burn yourself. I reccomend ceramic coating the intake to help fight heatsink that much more, and of course get you style points  8)
Reply #17August 24, 2006, 08:25:34 pm
Kudagra
  • 738
    • www.no-coast.com
Manifolds
« Reply #17 on: August 24, 2006, 08:25:34 pm »
Wll lets see em...
Or send me some pics and I wont share. :D
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #18August 24, 2006, 10:41:23 pm
935racer
Manifolds
« Reply #18 on: August 24, 2006, 10:41:23 pm »
I will be sharing these dont worry :D  The head flanges are one week away today(or so the laser cutter tells me, pray its true!) Than give me a couple days and the weekend to get some pics. I should have taken some pictures of the othermanifolds I made   :roll:  I cant wait to pop off a few more :D
Reply #19August 25, 2006, 03:51:36 pm
Kudagra
  • 738
    • www.no-coast.com
Manifolds
« Reply #19 on: August 25, 2006, 03:51:36 pm »
Well Im in line....
Reply #20September 18, 2006, 01:11:20 pm
derek510galaxy
  • 9
Manifolds
« Reply #20 on: September 18, 2006, 01:11:20 pm »
Dave,
  Yes, I'd certainly be interested in your exhaust manifolds for IDI TDs. So you also have plans for a nice flowing intake to work with this setup? That would be sweet. So if the turbo sits straight out from the exhaust ports ( not up or down as dictated by the factory manifold ) it would clear the shift linkage ( in a MKI ) and allow for a properly radiused intake tract? Will require downpipe mods for those already committed, but I suppose you'll have that too?
  Maybe you should create a finance portion of Passenger Performance so I can afford all the goodies you offer... :D
Thanks, Derek
1979 Rabbit TD (in the works)
1983 Rabbit GTI (350,000 miles)
Reply #21September 18, 2006, 03:06:30 pm
935racer
Manifolds
« Reply #21 on: September 18, 2006, 03:06:30 pm »
Guess I should update everyone, I got a few laser cut flanges, and lets just say I am going for better quality. The new flanges will be cut on a CNC mill and will be port matched. The added flow I will get from these new flanges will be worth the wait. The intake manifold head flange will incorporate the intake ports 60degree angle for maximum flow. Unfortunately the flanges are approx. 4 weeks away :cry:  So its still gonna be a while, which sucks because I have so many people asking for tubular manifolds!
Next week I will have the end caps for the intake plenums comming in so I will get some plenums fabricated and post some pictures. If I have time I will try and fab up some collectors for the exhaust manifolds as well.
The 2 different exhaust manifolds will fit a1-a4 chassis and engines, its the downpipes that will vary from chassis to chassis. So I will need someone to volunteer their mk1 and mk4 for those.
Financing... I already have my plate full so it looks like it overtime for you :lol:  Once I get a few of these suckers made I'm sure you'll find ways to come up with the cash, I will make them as affordable as I can, but I will not sacrafice quality for cost. You won't be seeing any log style manifolds here :D
Reply #22September 18, 2006, 04:32:17 pm
  • 1156
    • Malone Tuning Ltd.
Manifolds
« Reply #22 on: September 18, 2006, 04:32:17 pm »
Nice update, I'm looking forward to results :)
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #23September 18, 2006, 04:36:21 pm
zagarus
  • 619
Manifolds
« Reply #23 on: September 18, 2006, 04:36:21 pm »
hmmm, so should i just wait for one of thses manifolds before i go ahead and drill a hole for my EGT sensor into my stock manifold?  so i take it we're looking at better air flow, lower EGTs, better spool up time, mo power!  :D
Reply #24September 18, 2006, 04:48:27 pm
935racer
Manifolds
« Reply #24 on: September 18, 2006, 04:48:27 pm »
The more power and boost you want to run the more necessary it is to upgrade your manifolds!
Reply #25September 18, 2006, 07:03:26 pm
Kudagra
  • 738
    • www.no-coast.com
Manifolds
« Reply #25 on: September 18, 2006, 07:03:26 pm »
I want ONE MIEEEELION pounds of boost!
Reply #26September 19, 2006, 08:28:16 pm
935racer
Manifolds
« Reply #26 on: September 19, 2006, 08:28:16 pm »
Here is a ghetto draft of the exhaust flange on solid works, I plan to have the flanges done in 3d on saturday. You can see a little bit how the port goes from the stock oval shape to a round shape to match the primaries.
And I got the machinest to do some test pieces for me so I could see his work. Seems all is well, here are some of the T3 style turbine inlet flanges I got him to cut, and drill/tap.
.5'' 1018CRS
Reply #27September 25, 2006, 06:42:58 pm
phil_j
  • 8
Manifolds
« Reply #27 on: September 25, 2006, 06:42:58 pm »
dave,
don't know if this is the right place to post, but if you're having a bunch done up, put me on the manifold list....no rush as you know, but I'll pick up whenever they're ready (also, let me know when you have an intercooler for mock up )
Reply #28September 25, 2006, 07:04:42 pm
Manifolds
« Reply #28 on: September 25, 2006, 07:04:42 pm »
i'm kinda curious what's up with making manifolds, they already are available for the gassers, and, they will obviously work on our cars...
Reply #29September 25, 2006, 08:58:50 pm
QuickTD
  • 1156
Manifolds
« Reply #29 on: September 25, 2006, 08:58:50 pm »
Your machinest must have a 5 axis mill. The transition from round to oval will be tricky to machine without one. I suppose it could be picked out with a ball mill on 3 axis equipment but it would cost alot, machine time =  money. I'd be tempted to squish the tubes a bit to get the transition, the result would be smoother and the machining WAY easier. Better clearance from the intake as well.
