Saab or Volvo intercooler?
Topic: Saab or Volvo intercooler? (Read 4083 times)
August 19, 2006, 07:36:58 am
zooky
August 19, 2006, 07:36:58 am »
I have a Saab Blackstone IC and a Volvo IC and am trying to decide which one to use. Mounting space is not a concern. I hear the Saab IC is good and the hose connections would work better giving me a cleaner install with less hose length. The Volvo IC is bigger and will complement my radiator nicely but the way the hose fitting are I would need alot more plumbing and would not be as neat. Is there a big difference on how these IC's perform?
August 19, 2006, 12:14:03 pm
entuzijast
August 19, 2006, 12:14:03 pm »
I can tell only that among first mods on a turbo saab is replacing stock with a Volvo IC....
Excuse me on my bad English
August 19, 2006, 03:04:14 pm
jackbombay
August 19, 2006, 03:04:14 pm »
IC from a 240? If you plan to run more than 22 PSI or so it's a good idea to tie the end tanks on to prevent it from blowing up or leaking. Friends of mine have run 26 through them without issue though.
August 19, 2006, 04:00:37 pm
zooky
August 19, 2006, 04:00:37 pm »
Volvo is what I figured, not sure what is off but it is huge. I guess if the Saab owners are swapping them that must mean something...
August 19, 2006, 05:09:30 pm
jackbombay
August 19, 2006, 05:09:30 pm »
It's rather thin too, about an inch? with black plastic end tanks? If so it's from 240, I'm not sure if the 740 had the same one or not.
August 19, 2006, 05:16:43 pm
zooky
August 19, 2006, 05:16:43 pm »
yea, thats what I got
August 19, 2006, 08:20:18 pm
andy2
August 19, 2006, 08:20:18 pm »
Both of those IC's don't flow that well (tube and fin design)as opposed to bar and plate,but I would pick the volvo one too as it should flow better than the sabb one.
August 20, 2006, 04:30:10 am
stewardc
August 20, 2006, 04:30:10 am »
Put the Volvo one on and sell me the Saab one
August 20, 2006, 09:47:33 pm
hillfolk'r
August 20, 2006, 09:47:33 pm »
ive got a saab 900 one
icut the end tanks off in anticipation of making it flow across than loop thru
and iwas gonna box it and make it a water toair too
some fabber want the core?
? ive still got the cut off end tanks
iwas gonna use the hose stubs on the new tanks
Throttle cables ftw
August 21, 2006, 11:36:23 pm
ISBjornen
User+
August 21, 2006, 11:36:23 pm »
take 2 intercooler from saab and weld it together. then you have an ic whit good flow that can handel about 400hp
Kristensen
August 22, 2006, 04:41:09 pm
anarchyx34
August 22, 2006, 04:41:09 pm »
I've owned a few volvos and I can say that 940/740 and 850 turbo intercoolers are huge. I never ran more than 15psi on those cars but I never had an intercooler problem.
Reply #11
August 22, 2006, 04:50:08 pm
Kudagra
Reply #11 on:
August 22, 2006, 04:50:08 pm »
just about any intercooler is better then NO intercooler.
The Saab ones came 2 ways. They were either ALL aluminum (early) or they were like the Volvo ones(later)...alum core with plastic crimped on ends. I personally have an early one. I was thinking of getting a semi IC and chopping it down to my specs and welding tanks on but its not like I have that much room anyway. So Ill just use my tiny Saab one and water spray it like the Subaru STis.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
