VWDiesel Blog
Facebook Group
VWD on Twitter
Torque specs
Topic: Torque specs (Read 1471 times)
September 19, 2023, 09:58:38 am
93Ford
Torque specs
September 19, 2023, 09:58:38 am »
I need the torque specs for the intermediate shaft pulley, injection pump mounting bolts, injection pump pulley nut, and the timing belt tensioner nut. Also should i use any loctite on any of the bolts/nuts. 1985 vw jetta 1.6 na diesel
Last Edit: September 19, 2023, 10:55:51 am by 93Ford
September 19, 2023, 10:07:14 pm
Re: Torque specs
September 19, 2023, 10:07:14 pm »
33ftlbs for the I-shaft, tensioner and cam bolt.
I use blue locktite on the I-shaft seal carrier bolts and I-shaft bolt.
I just snug the injection pump mounting bolts/nut.
Tornado red, '91 Golf 4 door,
September 20, 2023, 09:40:28 am
Re: Torque specs
September 20, 2023, 09:40:28 am »
The Bentley is worth having.
September 20, 2023, 11:02:36 pm
Moderator
Re: Torque specs
September 20, 2023, 11:02:36 pm »
IF you have VW keys you should have a Bentley Manual.
Torque specs
