Fixmyvw.com
Author Topic: Mk2 ce2 headlight switch behavior  (Read 5044 times)
August 24, 2023, 09:16:51 pm
oblique
  • 276
« on: August 24, 2023, 09:16:51 pm »
Ok so I've tried now 5 or 6 switches and still have the same issue - i do not have an 'off' position.
I know these fail a lot so i don't know if Its just bad switches or something.
Car is a 1990 so ce2, no fogs. Am i correct that dual position (excluding off position) are for foglight cars and single position (excuding off, so plain on/off) are for non foglight equipped cars? I get the same behavior with both types...my taillights and running markers are always on, headlights are off until i flip the switch.
Reply #1August 25, 2023, 01:46:41 am
  • 2743
Re: Mk2 ce2 headlight switch behavior
« Reply #1 on: August 25, 2023, 01:46:41 am »
Have you taken any of the switches apart?
 I had to pull mine apart recently because the lights wouldn't come on.
Better to open them up and clean the contacts before they melt, I had to add some plastic (zip tie) to mine.
Tornado red, '91 Golf 4 door,
Reply #2August 30, 2023, 08:18:06 pm
oblique
  • 276
« Reply #2 on: August 30, 2023, 08:18:06 pm »
At this point, after so many switches with same behaviour I am hoping its something else. There's no dedicated headlight relay but there are 'multipurpose' relays that may interact with the headlights?? Are diesels same as gassers in this regard?
Reply #3August 31, 2023, 11:28:43 am
Dennis Froelich
  • 232
« Reply #3 on: August 31, 2023, 11:28:43 am »
Have you tried replacing the hazard switch? When they go bad the lights act weird.
79 Golf GTD
96 Golf GTD(TDI)
Reply #4August 31, 2023, 11:15:03 pm
  • 2743
« Reply #4 on: August 31, 2023, 11:15:03 pm »
Maybe a bad ground then.
 That can make lights do funny things.
If there is no ground, current will sometimes flow backwards through the lights to get to a ground on the low beams or something.
S-PAutomotive.com
