Author Topic: What is a symptom of the piston striking the head?  (Read 5831 times)
July 04, 2023, 01:48:50 pm
Gnarlodious
  • 25
« on: July 04, 2023, 01:48:50 pm »
I have a '77 Rabbit 1.5 engine 56,000 miles. I put a new rebuilt head on it less than a thousand miles ago, it has a 4-notch gasket. Compression is excellent, has great power, starts easily. Recently it has set up a sharp knock that sounds a little concerning. The knock goes away when the engine is hot and at cruising speed. It is intermittent but may partially return when the engine cools a little. I have rotated the crank manually but no indication a piston is striking the head. I've driven it maybe 100 miles with the knocking. Am I on the right track with this diagnosis? Does it sound like I need to take the head off for inspection? Am I safe to drive it until I can fix it?
’83 Vanagon AAZ
Reply #1July 04, 2023, 06:30:25 pm
  • 2932
Re: What is a symptom of the piston striking the head?
« Reply #1 on: July 04, 2023, 06:30:25 pm »
Maybe it's an injector.
 Does it knock when you step on it then go away when you let off?
Reply #2July 05, 2023, 11:56:17 am
Gnarlodious
  • 25
« Reply #2 on: July 05, 2023, 11:56:17 am »
No, it knocks mostly when it's cold and below operating temperature. Seems to be worse under no-load conditions. I would almost think it is piston slap except only 46k miles on this block. Knock goes away or is greatly reduced upon continuous cruising.
I've ordered a 5-notch head gasket for it, so will report back when I know more.
’83 Vanagon AAZ
Reply #3July 05, 2023, 11:13:56 pm
  • 2932
« Reply #3 on: July 05, 2023, 11:13:56 pm »
 When the engine was rebuilt,
 did it get new piston rod bushings and get them reamed?
Reply #4July 06, 2023, 06:24:15 am
Gnarlodious
  • 25
« Reply #4 on: July 06, 2023, 06:24:15 am »
I wasn't rebuilt, original 1978 engine. My grandfather's car. I put a reconditioned head on it last year, bought from The Parts Place. But evidently that head was shaved as far as it could go.
’83 Vanagon AAZ
Reply #5July 06, 2023, 08:01:25 pm
sgnimj96
  • 185
« Reply #5 on: July 06, 2023, 08:01:25 pm »
I'd pop-test the injectors before removing the head.
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #6July 07, 2023, 05:13:33 pm
Gnarlodious
  • 25
« Reply #6 on: July 07, 2023, 05:13:33 pm »
Has new injectors and a rebuilt pump.
’83 Vanagon AAZ
Reply #7July 07, 2023, 09:29:50 pm
  • 2932
« Reply #7 on: July 07, 2023, 09:29:50 pm »
 I'd still test the injectors.
 New injector inserts aren't as good as they used to be.
Could be a pisser,
 or could be the rod bushings on the small ends of the rods.
Reply #8July 10, 2023, 01:34:39 pm
Jetmugg
  • 530
« Reply #8 on: July 10, 2023, 01:34:39 pm »
Milling the head will have no affect on pistons hitting the head.  The head surface is flat, with no built-in "combustion chamber" of any type.
