AMC 1.6TD head after 5000miles
Topic: AMC 1.6TD head after 5000miles (Read 5527 times)
June 05, 2023, 05:04:59 am
oblique
Diesel while you can.
June 05, 2023, 05:04:59 am »
Swapping bottom ends, I was burning more oil than diesel. Before and after cleanup.
The alloy is definitely softer than stock. When I removed the turbo bolts with an impact, the extension touches the edge of the head and dented the head at the edge much more than OE.
The off-white deposits..are those the oil it was burning?
Last Edit: June 05, 2023, 06:50:53 pm by ORCoaster
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
June 05, 2023, 06:52:25 pm
Moderator
4553
Re: AMC 1.6TD head after 5000miles
June 05, 2023, 06:52:25 pm »
Wow, not the normal micro-cracks between valves on that head. Cleaned up as it is, I would say slap it on and give it a go.
June 05, 2023, 07:46:09 pm
June 05, 2023, 07:46:09 pm »
That is a nice looking TD head.
Like ORC said, it's rare to have no cracks between the valves.
One way to tell if it's warped is to remove the cam caps and lifters.
Then see if the cam teeter-totters in the head.
June 06, 2023, 01:37:46 am
oblique
June 06, 2023, 01:37:46 am »
This head was put on brand new about a year ago after a timing belt break - my old OEM head was trash. Ive only put on about 5k miles so far.
It's the aftermarket Made in Spain stuff.
90 1.6TD Jetta
79 1.6Na Rabbit
June 06, 2023, 07:44:29 pm
June 06, 2023, 07:44:29 pm »
The head is a big part of the puzzle.
Nice to have a good one you can swap over to the fresh block you are building.
