Author Topic: Injector overflow nipple removal  (Read 5078 times)
January 08, 2023, 12:34:57 pm
33B
  • 58
    Bosnian with a money pit aka VW Passat 1987
« on: January 08, 2023, 12:34:57 pm »
How do you remove the injector overflow nipple?
I bent one when replacing the injector heat shields and a crack formed making it leak.
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
Reply #1January 08, 2023, 02:07:53 pm
  • 4549
Re: Injector overflow nipple removal
« Reply #1 on: January 08, 2023, 02:07:53 pm »
Hmm,  Never had to deal with that one.  Can't see drilling them out and replacing them either.
time to get a new body for it.  If you need one say something as I and most others likely have a stockpile of old injectors that we could send easily.
Just looked at your location info.  Probably not something we in the states would be able to send quickly.
« Last Edit: January 08, 2023, 02:09:39 pm by ORCoaster »
Reply #2January 08, 2023, 05:27:32 pm
  • 2926
« Reply #2 on: January 08, 2023, 05:27:32 pm »
Since the one on the end usually gets plugged anyway.
 You could probably just weld it shut and put it on cylinder 1 or 4.
Reply #3January 09, 2023, 08:03:26 am
sgnimj96
  • 185
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #4January 09, 2023, 10:31:25 am
33B
  • 58
« Reply #4 on: January 09, 2023, 10:31:25 am »
Thank you for your suggestions. Most likely i'll weld it shut.
Reply #5January 09, 2023, 05:40:05 pm
  • 4549
« Reply #5 on: January 09, 2023, 05:40:05 pm »
A Zap or two from the ole electric beast and your problem is solved.  I like it.
Reply #6January 11, 2023, 05:26:45 pm
sgnimj96
  • 185
« Reply #6 on: January 11, 2023, 05:26:45 pm »
good ol' JB Weld would probably work also.    Spray it with brake cleaner and cover the whole thing.
Unfortunately, there would be some downtime waiting for it to fully cure.
