Author Topic: Need info for camshaft database  (Read 2191 times)
August 15, 2006, 06:41:32 am
TDIMeister
  • 284
« on: August 15, 2006, 06:41:32 am »
Hi, guys,
I have been developing a database for VW camshafts for the past three years or so, and to date I have specs for about 30 VW Diesel cams -- OEM, aftermarket, and my own designs -- as well as about a two dozen more VW gas cams, also OEM and aftermarket...
I am missing data for the OE VW 1.6 and 1.5 Diesel cams, and would appreciate if someone could assist me in filling out these information.  VW part numbers and the engine codes in which they were installed would be helpful to me, just as you see in the top row of the screenshot.
Also, if you know the specs of other OE- or aftermarket VW cams, for gassers or Diesel, I think it would be useful to have them listed in the database as well.
A screenshot of my work is below.  Please provide as much data you have in the same format as in the light green fields in the upper part of the worksheet.  Usually I can calculate or extrapolate missing information so that the data you provide doesn't have to be complete, but every bit helps. :)  Accuracy here is key, and to ensure that, please also where possible cite the source of the information (e.g. Bentley manual, SAE paper, name of company performing the measurements, etc.).
I believe between the Description fields and Notes below on the bottom of the picture, you should be able to figure things out. :)
Thanks very much in advance, guys!
Reply #1August 15, 2006, 08:28:55 am
935racer
« Reply #1 on: August 15, 2006, 08:28:55 am »
I've got the specs for those kicking around, I'll try and them up, I am sure I have them in one of my old notebooks.
