Author Topic: 1.6td mf block injection pump  (Read 4552 times)
November 08, 2022, 06:39:43 pm
85bertajetta
  • 17
    trying to save an abused jetta
« on: November 08, 2022, 06:39:43 pm »
I'm having some issues with my injection pump. It sat with water in it and has some rust.
Is there a different pump, maybe from a newer engine that's easier to find that will work for this unit?
 I'm also having issues getting the pully off, so I might have to cut that.  Any input would be appreciated
« Last Edit: November 09, 2022, 04:11:08 pm by ORCoaster »
Reply #1November 08, 2022, 07:47:10 pm
  • 2932
Re: 1.6td mf block injection pump
« Reply #1 on: November 08, 2022, 07:47:10 pm »
Any bosch rotary from a 1.6 VW diesel will work.
 Have you tried a gear puller on the sprocket?
Reply #2November 16, 2022, 06:32:57 pm
oblique
  • 317
    Diesel while you can.
« Reply #2 on: November 16, 2022, 06:32:57 pm »
Does this include NA pumps? Just to avoid confusion because they are easier to find at junkyards, etc
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #3November 16, 2022, 09:35:07 pm
  • 2932
« Reply #3 on: November 16, 2022, 09:35:07 pm »
Right, you can use an NA pump.
 It will smoke more before boost kicks in.
