Author Topic: aaz build, need some help on setup.  (Read 3717 times)
September 19, 2022, 07:43:19 am
Rodry_rad
  • 1
« on: September 19, 2022, 07:43:19 am »
Hi folks! I have a vwT4 with an aaz engine full rebuild and I need recommendations on the setup, I want to reach 110hp aprox and be reliable for every day.
I am adding a front intercooler, oil cooler and a 5th gear modification.
I'm in doubt as to which turbo and how many millimeters of pump head would be the most convenient.
I have 2 turbos that could use a k03 38/46 wheels and a GT1749S 44/49.
Do you think any of these would serve this purpose? And what size pump head do you recommend?
Thanks for your time!!!
Reply #1September 27, 2022, 03:24:01 am
Tomoturbo55
  • 57
Re: aaz build, need some help on setup.
« Reply #1 on: September 27, 2022, 03:24:01 am »
Stock pump Will manage 110 HP, 1.6 TD boost pin and some fuel screw, for the turbo k03 is too small use gt17 if its only option.
