VWDiesel Blog
Facebook Group
VWD on Twitter
ARP Headstuds on 1.6TD retorque or not?
Topic: ARP Headstuds on 1.6TD retorque or not? (Read 3569 times)
February 07, 2022, 04:05:49 pm
Ohiobenz
February 07, 2022, 04:05:49 pm »
ARP paperwork states a retorque after initial warmup is not necessary.
I'm reading posts on other non VW forums indicating issues if not retorqued.
When I ran the studs in I took them all the way to the bottom, then backed off a couple turns, then hand tightened them.
I used the provided lube on the studs and washers when torqueing the head down.
The engine has now run through a full heat cycle and I'm debating whether to follow the ARP or other forum advice?
'88 Suzuki Samurai with '85 1.6 TD
K14 turbo
BOV eliminated
Giles performance built IP
February 07, 2022, 07:13:43 pm
RustyCaddy
Re: ARP Headstuds on 1.6TD retorque or not?
February 07, 2022, 07:13:43 pm »
On my rebuilt 1981 11mm block i retorqued the ARP head studs. But that was 150,000 miles ago with a couple more loosening and retorquing cycles since they were installed. Seems to be holding pretty well, no jinx intended.
February 07, 2022, 08:50:03 pm
Ohiobenz
February 07, 2022, 08:50:03 pm »
With the K14 turbo it gets into boost pretty quick.
I've run 2 heat/cool cycles just in the shop so far without driving it.
When you did the retorque did you back off then retorque or just tightened?
K14 turbo
BOV eliminated
February 09, 2022, 09:42:12 pm
RustyCaddy
February 09, 2022, 09:42:12 pm »
I backed off a 1/4 turn and then retightened, doing one headbolt at a time following the manuals tightening sequence IIRC
March 07, 2022, 01:32:52 pm
March 07, 2022, 01:32:52 pm »
follow the arp directions, these are completely different fasteners from stock.
my horror story is with an 11mm block. i did a hot retorque and it cracked the block. the stud just spun and when i removed it and looked down into the threads i could it see it filling with coolant.
March 07, 2022, 11:23:20 pm
March 07, 2022, 11:23:20 pm »
That's weird.
The stud isn't supposed to spin.
Tornado red, '91 Golf 4 door,
March 08, 2022, 01:26:14 pm
Moderator
March 08, 2022, 01:26:14 pm »
It will if you break it or strip it out. Which is my guess of what happened. Hot aluminum is not real strong.
March 08, 2022, 11:13:46 pm
March 08, 2022, 11:13:46 pm »
It's not screwed into aluminum.
I'm wondering if people are following the advice to send the studs all the way to the bottom.
I think the metal in the studs expands at a different rate than the cast in the block.
That can exert a tremendous force on the block and threads.
I also think that if the stud is all the way against the bottom of the hole
and you turn that stud in farther, even a little bit as you torque it down
it will also exert an enormous amount of force pushing up on the stud
while the nut is pulling it upward exerting more force in the same direction.
I always bottom the stud them back off a turn.
Then make sure it doesn't turn more as the nut is snugged up before torquing.
Oh and on topic:
I don't think I ever retorqued the studs I've used and have never had a problem with the head gasket letting loose.
But I don't see a problem with backing them off a little and retorquing if I had the valve cover off.
I read another thread on here where the person decided it was better to torque them more than the manufacturer
suggested. Don't do that.
Last Edit: March 08, 2022, 11:18:47 pm by fatmobile
March 09, 2022, 07:16:11 pm
Moderator
March 09, 2022, 07:16:11 pm »
Geez another duh moment for me. Aluminum head, not block, Not thinking real clearly these days. Too many of life's troubles going on around me. My head hurts all day as I bumble from one calamity to another. But I come here to try and help. I just don't always get it right.
I am not even sure what ARP recommends for a torque limit on their product. I recently had suspected blowby and retightened the whole set to what was in the Bentley. I am now wondering if I should have gone more than that.
March 10, 2022, 12:21:52 am
March 10, 2022, 12:21:52 am »
It's a crazy world right now.
I'm not sure what the torque is supposed to be for the ARP stuff.
Might be 80.
I think 11mm studs are 95ftlbs.
March 10, 2022, 07:44:25 pm
Moderator
March 10, 2022, 07:44:25 pm »
I think I will go look as I don't think I was much over 70 lbs with the wrench. I will check the dial on it as I put it away set to what I used. That would be good to go to 95 if i can. That might stop my blowby, being low might have been the problem.
Edit for numbers: This is what I got for a 1.9 turbo diesel engine. 125 ft/lbs
https://tech.arp-bolts.com/instructions/204-4706.pdf
Last Edit: March 10, 2022, 07:50:59 pm by ORCoaster
Reply #11
March 10, 2022, 10:30:59 pm
RustyCaddy
Reply #11 on:
March 10, 2022, 10:30:59 pm »
On the 11mm started out at 80 ft/lb. The last time went to 95.
They have held but I am losing a little coolant between oil changes now and might go up to 100 this next time, or the coolant tank cap is failing.
It is all an experiment
, caution advised. Good point about a cold engine block-have always retorqued when cold.
There should be more information on this board or it might have been on the Vortex; those posts would be at least 12 years old by now.
Last Edit: March 10, 2022, 11:05:28 pm by ORCoaster
Reply #12
March 11, 2022, 10:53:43 pm
Reply #12 on:
March 11, 2022, 10:53:43 pm »
I wouldn't go higher than 95 on the 11mm heads.
ORCoaster: Is the torque sequence on the ARP link wrong?
I think it's mirror image of what's in the bentley but,..
was going to say my bentley was outside but the truth was too lazy too look, ha.
Yep wrong.
According to my MK2, 1.6 Bentley official factory repair manual,.. that is still in the house.
Reply #13
March 12, 2022, 12:55:46 am
Moderator
Reply #13 on:
March 12, 2022, 12:55:46 am »
I was going to say that the link was for the newer 1.9 L engines but I see that it covers the 1.6 as well so yeah. A guy could have 11 mm heads on a block.
But are the ARP studs better-made steel than an 11 mm bolt? Thereby being able to take more torque? I really don't know about that. I was thinking of doing another sequence of tightening on my head gasket now that I see I have more potential to get it right and tight.
As for the sequence of bolts to tighten I thought it was correct. You just need to bounce back and forth on that process so you don't get one side too tight. I think the sequence allows for one to get the middle down and works it out toward the ends. Possibly to remove any warpage.
Reply #14
March 12, 2022, 01:40:18 am
RustyCaddy
Reply #14 on:
March 12, 2022, 01:40:18 am »
Again, this is from old memories but IIRC when folks were using the AAZ metal head gasket on 1.6 hydraulic blocks (MF certainly) ARP 204-4706 studs were going up to 125 ft/lbs. With a fiber gasket it seemed like that much compression wasn't needed though? There is something about being able to go a certain spec over manufactures recommendations; what comes to mind is that Raceware studs were recommended at 50-55 ft/lbs but could go up to 70-80. The difference was the studs failing vs the block failing.
But i defer to you guys on all things VW diesel.
The point about not going to 100ft/lbs is well taken on my 11mm block. Can't remember the ARP part number for 11mm blocks for sure but may have ended with 4701 and were made for a Cosworth?
Originally the motor had the 1.5 head on a 1.6 block combo so it needed to be well clamped down. Started incredibly easy on cold days.
Last Edit: March 12, 2022, 01:55:34 am by RustyCaddy
