Author Topic: 06 TDI Jetta Cranks But NO Start  (Read 40644 times)
December 01, 2021, 10:41:04 pm
lovevws
  • 12
« on: December 01, 2021, 10:41:04 pm »
06 Jetta tdi, I think BRM engine code, automatic transmission
Cranks, but wont start.
Tachometer moves a bit while cranking. Ive put quite a lot of hours into working on this to get it running, but nothing.
Trouble code says crank position sensor, so replaced it many times, doesnt fix it, still wont run.
Replaced in tank fuel pump, still nothing. Pump pressure is good.
Replaced the high pressure pump, nothing, no difference.
Made sure the belt was spinning the cam shaft, all good.
Does anyone know some sort of trick of what to check?
Reply #1January 15, 2022, 10:35:48 am
matt16
  • 41
Re: 06 TDI Jetta Cranks But NO Start
« Reply #1 on: January 15, 2022, 10:35:48 am »
regarde si tu as un signal de rpm au vag com
vw un etat d'esprit
