Author Topic: Dash rebuilt.  (Read 9881 times)
November 09, 2021, 02:54:50 pm
Dash rebuilt.
« on: November 09, 2021, 02:54:50 pm »
The old from about 7 years ago. Was worse by the time I started working on it.
After the recent rebuild
The gauges:
Reply #1November 09, 2021, 07:28:47 pm
Re: Dash rebuilt.
« Reply #1 on: November 09, 2021, 07:28:47 pm »
what is the secret to the fix?   Fiberglass resin? Truck bed liner?
Reply #2November 09, 2021, 07:44:15 pm
Re: Dash rebuilt.
« Reply #2 on: November 09, 2021, 07:44:15 pm »
Yes I copied what I saw others do on youtube
I did use ultralight bondo type filler. after widening the cracks Then used 80 grit. and hand sanded it. A can of duplicolor truck bed aerosol in black for 8 dollars a can. Had to use a second can to finish the glovebox cover.
The thing was way more warped than in the picture. I used epoxy flox and bonded in a 32" 1/4" steel rod about an inch behind the front edge underneath. Once clamped and cured it really stiffened up the particle type material that the dash structure is made of.
I drove the car a couple of times without the dash and liked the open space but seemed simpler just to put it back in.
Reply #3November 09, 2021, 09:25:09 pm
Re: Dash rebuilt.
« Reply #3 on: November 09, 2021, 09:25:09 pm »
You have to be kidding me, I pulled those items out of thin air.  I had no idea that they would do the job.  Nice to know if I ever have to "restore" a dash.
