Author Topic: DIY Boost Controller?  (Read 3565 times)
August 13, 2006, 01:06:10 pm
klr650@
  • 52
« on: August 13, 2006, 01:06:10 pm »
http://www.geocities.com/chmwatson/FAQs/mbc.html
Found this DIY boost controller. Anyone every done this before? Does it sound like a good setup?
1993 Suzuki Sidekick w/ 1.9TD
Reply #1August 13, 2006, 01:38:30 pm
hillfolk'r
  • 1532
« Reply #1 on: August 13, 2006, 01:38:30 pm »
just use an old shop air regulator for 15 bucks at home depot
campbell hausfield "mini shop air regulator" in the tools section at the depot
i like to make my own stuff,but i said why bother ??
this works great
Throttle cables ftw
Reply #2August 13, 2006, 02:02:13 pm
klr650@
  • 52
« Reply #2 on: August 13, 2006, 02:02:13 pm »
That's the answer I was looking for... I was searching for something like your setup and came across this article. THought I might give it a try, but not anymore. I'm going with your setup. Thanks!
Reply #3August 14, 2006, 12:54:19 am
ssray
  • 30
« Reply #3 on: August 14, 2006, 12:54:19 am »
hillfolk'r is your car that loud that you need earplugs? I SAID IS YOUR CAR......
Ray
Reply #4August 14, 2006, 02:33:26 am
« Reply #4 on: August 14, 2006, 02:33:26 am »
3/16" didn't cut it for me, I had to bore to 1/4"
Other than that, mine works on the same priciple, an dis effective.  I beleive iine is a 'steam pressure releif valve'  it has 1/2" 28tpi straight thread popular in flash supressors lilencers and muzzle brakes.  The fine thread makes precision adjustment easier, but good luck finding a tap or die like that.
Reply #5August 14, 2006, 11:27:25 am
« Reply #5 on: August 14, 2006, 11:27:25 am »
MORE MORE MORE!!! :twisted:
Reply #6August 14, 2006, 04:59:09 pm
hillfolk'r
  • 1532
« Reply #6 on: August 14, 2006, 04:59:09 pm »
lol ssray :P
yea,i wear them on long road trips,like when i drive my 8 hour trip to ny
the noise does make ya tired on a long trip like that
but drivin around here,i dont wear them
much over 2 hours though,i will wear them
my exhaust  is  just straight pipe with a turndown exiting before the rear axle :twisted:
Throttle cables ftw
Reply #7September 03, 2006, 06:57:02 pm
klr650@
  • 52
« Reply #7 on: September 03, 2006, 06:57:02 pm »
Ok, so what can I use for the hoses? I've got some clear 1/4" ID left over from the fuel lines I replaced. Can I use them?
Reply #8September 03, 2006, 08:50:58 pm
« Reply #8 on: September 03, 2006, 08:50:58 pm »
Quote from: klr650@
that should work.  as long as you get a good seal.  remember that if it breaks, you do not have control over the boost your car makes anymore  :shock:
