Author Topic: Head Gasket sizes  (Read 8999 times)
Reply #15August 05, 2021, 10:54:09 am
harpy
  • 18
Re: Head Gasket sizes
« Reply #15 on: August 05, 2021, 10:54:09 am »
Got the one notch MLS gasket like 16 hours after I ordered it.
I've never seen anything like this before -- literally multiple thin layers of steel not fully bonded? Was surprised at first and thought it was delaminated. I also noticed there are no additional gaskets around oil holes or anything.
 Should I add any additional sealant to the gasket? Hylomar spray? Hylomar tube? Going to install this weekend!
Reply #16August 05, 2021, 02:37:11 pm
« Reply #16 on: August 05, 2021, 02:37:11 pm »
I do a very light coating of hylomar spray (not the tube) on both surfaces of the gasket, the block, and the head.
Reply #17August 05, 2021, 08:55:26 pm
  • 2926
« Reply #17 on: August 05, 2021, 08:55:26 pm »
 and he means light.
Especially if you are doing the head and block too.
Don't spray the whole thing blue.
 Hylomar doesn't harden and will spread/squeeze out when torqued.
Reply #18August 05, 2021, 09:42:03 pm
  • 4549
« Reply #18 on: August 05, 2021, 09:42:03 pm »
I Second on the go light spray with it.  You don't need a gob of it, just a very light coat.
Make that VW engine feel like a Royal Royce.  Just add Hylomar.
Reply #19August 06, 2021, 07:38:09 am
harpy
  • 18
« Reply #19 on: August 06, 2021, 07:38:09 am »
You know I looked back at some old threads and saw your testimonial on using hylomar, but I couldn't be sure you meant on MLS gaskets too.
Thanks again everyone -- I'll do a light spray on everything and bolt everything up!
Appreciate y'all.
