VWDiesel Blog
Facebook Group
VWD on Twitter
Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
Oil Pan Bolt Under Tranny
Topic: Oil Pan Bolt Under Tranny (Read 2057 times)
July 08, 2021, 10:19:58 am
mstephenson
User+
July 08, 2021, 10:19:58 am »
1.9 1Y
5-speed
One of the two oil pan bolt holes located under the tranny is cross-threaded. Do I need to unbolt and move tranny to retap hole or can I notch the tranny to get a straight tap? Or is there another, easier way?
thanks.
July 08, 2021, 11:27:11 pm
Moderator
Re: Oil Pan Bolt Under Tranny
July 08, 2021, 11:27:11 pm »
What do you think about using the next size of the bolt but make it a self-tapping one? Be easier than cutting a clearance hole I would expect. The oil pan bolts are 6 mm I think, You could upsize to 7 mm.
Just thoughts.
July 09, 2021, 07:44:14 am
mstephenson
User+
July 09, 2021, 07:44:14 am »
Thanks. That sounds doable. Only the first two threads or so are crossed. The idea of botching this is not appealing.
m
