Author Topic: Draining the transmission on an MK1  (Read 5842 times)
April 04, 2021, 05:13:12 pm
« on: April 04, 2021, 05:13:12 pm »
What am I thinking that is wrong here?  I want to check fluid level and quality on my Caddy with an 020 FF transmission. Bentley's manual shows the drain and fill holes but doesn't say the size.  I thought they were 17 mm.
Is that not correct?  I can't seem to fit my 17 mm hex for my 3/8ths inch drive in the space provided.
What tool do you use to get those out?
I may be looking at some nuts and a bolt to put up in there and turn it with a socket instead of the breaker bar.
Awaiting answers.
Thanks.
Reply #1April 05, 2021, 07:45:11 am
Re: Draining the transmission on an MK1
« Reply #1 on: April 05, 2021, 07:45:11 am »
Mine are 17mm, maybe yours took a hit and messed up the hole. That's odd
Reply #2April 05, 2021, 04:28:32 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #2 on: April 05, 2021, 04:28:32 pm »
17 mm Allen is what mine is. I guess the in vogue thing is to call it a hex key nowadays, but I still call them Allen wrenches.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #3April 05, 2021, 05:41:14 pm
« Reply #3 on: April 05, 2021, 05:41:14 pm »
I thought it may have taken a bump and so I ran my finger along the edges and even tried a flat-file in there.  No joy and I tried to hammer my big Allen wrench in there and it was denied.
I think I have some 16 MM nuts and a bolt hanging around here somewhere.  I may see if those go in the plug.  If so I may invest in a 16 MM hex head on a 3/8ths inch drive.  Very odd as my Rabbit uses the 17 mm ones no problem.
Maybe someone swapped the transmission somewhere along the line and bought non-stock plugs for it.  Sure a pain in the shoulder to get under there.
Reply #4April 05, 2021, 09:27:31 pm
  • 2931
« Reply #4 on: April 05, 2021, 09:27:31 pm »
 A 5/8" bolt head is the same as 16mm.
 That's weird that a 17mm allen wrench won't fit.
 A lug bolt is the usual goto.
Reply #5April 06, 2021, 08:26:38 pm
« Reply #5 on: April 06, 2021, 08:26:38 pm »
Thanks for the conversions and another use for a Lug bolt.  I keep several of them in the ammo box with the hydraulic jack in the Caddy.  I had walking bolts for a little while and I needed to have spares on hand, or on the road rather.
