VWDiesel Blog
Facebook Group
VWD on Twitter
For Sale/Looking For
Parts for Sale/Wanted
Mk1 Rabbit or Jetta Blower Motor for AC/heater Needed
Topic: Mk1 Rabbit or Jetta Blower Motor for AC/heater Needed (Read 4530 times)
February 04, 2021, 10:24:57 am
tbro
User+
February 04, 2021, 10:24:57 am »
I need a replacement for my 1982 Caddy heater/AC blower motor. The bushings are shot in my current motor and upon removal it seems to be non rebuildable. I am open to any suggestions on being able to replace bushings (if possible) from someone who has done this. Thanks for your comments, Tom
February 04, 2021, 07:32:07 pm
Re: Mk1 Rabbit or Jetta Blower Motor for AC/heater Needed
February 04, 2021, 07:32:07 pm »
They are readily available new for <$50.
February 05, 2021, 12:26:38 am
February 05, 2021, 12:26:38 am »
Hey Andrew,
Is that for the bearings or the MK1 AC heater fan?
Tornado red, '91 Golf 4 door,
February 05, 2021, 09:54:38 am
tbro
User+
February 05, 2021, 09:54:38 am »
Thank you for the reply. Do you have a link or name of a place that cell the fan motor?
February 05, 2021, 10:53:06 am
February 05, 2021, 10:53:06 am »
I might have been mistaken. I got one recently for my rabbit, but it does not have A/C. If they are different for the vehicles equipped with A/C, then ignore my post.
February 05, 2021, 12:43:56 pm
Moderator
February 05, 2021, 12:43:56 pm »
Try one of these places.
https://www.partsplaceinc.com/vw-heater-blower-motors.html
https://www.partsgeek.com/ss/?ssq=vw+pickup+blower+motor&year=1982
Just a click away.
February 06, 2021, 02:03:32 am
tbro
User+
February 06, 2021, 02:03:32 am »
Those look nothing like the one in my AC Rabbit pickup.
I would like to post a picture of the unit but can't seem to get it to work. Any ideas how to post a picture? I looked at help section but it did not work for me. Thanks
Last Edit: February 06, 2021, 02:17:14 am by tbro
February 06, 2021, 11:54:29 am
Moderator
February 06, 2021, 11:54:29 am »
Did you not find this in the FAQs. It is sort of buried in there.
http://vwdiesel.net/forum/index.php/topic,13132.0.html
February 06, 2021, 11:43:29 pm
tbro
User+
February 06, 2021, 11:43:29 pm »
Thank you OR coaster it worked! Not mine but identical to the one in my AC caddy.
Last Edit: February 06, 2021, 11:50:23 pm by tbro
February 07, 2021, 01:37:08 am
February 07, 2021, 01:37:08 am »
I looked a little to see if I could find one. Here's the only one I came up with:
https://www.thesamba.com/vw/classifieds/detail.php?id=2350874
February 07, 2021, 01:58:54 am
February 07, 2021, 01:58:54 am »
I've looked for the bushings but couldn't find any the right size.
Ended up making a few on my lathe.
They are 8mm hole and are round on the outside.
I don't remember what they are called.
Reply #11
February 07, 2021, 10:35:36 am
tbro
User+
Reply #11 on:
February 07, 2021, 10:35:36 am »
Thank you both for your comments. Making the bushings is no problem for me. Dismantling the armature case is the problem since the case is staked together and the squirrel plastic fan seems to be epoxied to the shaft. I tried pressing the shaft through the fan but stopped before I broke the plastic. If I can remove the fan I probably can deal with the case which houses the bushings.
The one in the picture Libby sent is different as I do not have the resistor. Thanks again for trying.
A real shame VW did everything to make the unit not rebuildable and then stopped making them available!
Reply #12
February 07, 2021, 10:45:36 am
tbro
User+
Reply #12 on:
February 07, 2021, 10:45:36 am »
Andrew, I sent an email to Samba seller to confirm status of bushings on his used motor.
Thanks again for looking for me
Reply #13
February 07, 2021, 07:57:12 pm
Reply #13 on:
February 07, 2021, 07:57:12 pm »
Quote from: tbro on February 07, 2021, 10:35:36 am
Hmmm, the one in the picture you posted has the resistor.
Reply #14
February 07, 2021, 09:07:28 pm
tbro
User+
Reply #14 on:
February 07, 2021, 09:07:28 pm »
Yes you are right. The one in my truck uses an a circuit board that is mounted to the heater enclosure on one side. I do not know if it makes a difference.
