Fixmyvw.com
Author Topic: Best way to spend money on my GTD  (Read 2331 times)
November 30, 2020, 02:27:30 pm
bamsarfield
« on: November 30, 2020, 02:27:30 pm »
mk2 gtd, 238k miles 1991
Has coil overs, exhaust and a few other minor bits done.
1.6TD, what are the best engine bits to do, I am looking at govern mod and injectors and have been told I need uprated clutch for this. Where can I get some more info.
Photo of current state: don't know how to upload a photo wtffff
Also, glow plug light doesn't come on dash, but glow plugs defo work. is this an easy fix?
« Last Edit: November 30, 2020, 02:30:27 pm by bamsarfield »
Reply #1November 30, 2020, 02:46:32 pm
Dennis Froelich
  • 229
Re: Best way to spend money on my GTD
« Reply #1 on: November 30, 2020, 02:46:32 pm »
Check out the FAQs on here!! Lots of info!!
79 Golf GTD
96 Golf GTD(TDI)
Reply #2November 30, 2020, 05:53:38 pm
bamsarfield
« Reply #2 on: November 30, 2020, 05:53:38 pm »
Hello, yes I have had a read, my view for this post was more on the side of what's the best value ones to do first, About £1000 to spend maybe more if its a large improvement.
Reply #3November 30, 2020, 06:46:20 pm
  • 4392
« Reply #3 on: November 30, 2020, 06:46:20 pm »
I have had the little light bulb come out of its socket in the cluster itself.  You can see if you have voltage on that contact but honestly pulling the whole gauge cluster out is the best way to prove it is working right.
Not so hard to do but you need to be able to curl up on the floorboard to get at the speedometer cable and big plug that goes into the back of the cluster.
Fixmyvw.com
