Author Topic: Gotta Do a clutch etc etc  (Read 11185 times)
Reply #30October 23, 2020, 11:05:50 am
Re: Gotta Do a clutch etc etc
« Reply #30 on: October 23, 2020, 11:05:50 am »
New Luk flywheel would probably be fine also.
Reply #31October 23, 2020, 07:44:38 pm
monst
  • 184
« Reply #31 on: October 23, 2020, 07:44:38 pm »
GTK..... Thanks!....
   I may go that route.......
   In the event I do.........      What I saw for "compatibility".....
               It said,,,,,,,,(requirements being)
Single Alignment Dowel Pin 7.4x1.75mm -
Also Use 027 198 141E Clutch Kit Or 027 141 026C Plate; Engine: VIN: K; Transmission: Manualless
Also Use 027 198 141E Clutch Kit Or 027 141 026C Plate; Engine: VIN: A; Transmission: Manualless
                             (have to research the kit #.... and why it makes that suggestion....)))
Just wondering     If anyone knows   Engine: VIN K
                                    AND           Engine  VIN A
                         What bit position are they lookin at for   VIN K   and VIN A......
                 I don't have my VIN in front of me....... I guess... perhaps I might be able to deduce... something if I did....
                                      VIN K and VIN A ...  (dont' have anythin to do with the plant which the wheels were manufactured??))
        I will have to look deeper if I am to purchase a new one..........
             (ebay ones are cheaper but, I believe are without the dowel pins)
                        The pins on ebay are  rather expensive..............
               Is it ok to reuse dowel pins?
                        When the old one gets resurfaced.........
                     what is the idea there????     reuse pins........ install new pins????  thanks......
MOnst
Reply #32October 24, 2020, 01:10:05 am
« Reply #32 on: October 24, 2020, 01:10:05 am »
I don't know about the VIN values.
It is fine to reuse the dowel pins.
Reply #33October 24, 2020, 06:58:28 pm
monst
  • 184
« Reply #33 on: October 24, 2020, 06:58:28 pm »
Gtk  thanks....
            I got another place to go with it on Mon....
Seems to think he can cut it.....     He has been in the bus... for  long time...
So I will see what his vibe is..........
       And explain.... dowel pins are to be removed.... both surfaces are to be machined.....
Monst
Reply #34October 24, 2020, 09:08:03 pm
  • 2932
« Reply #34 on: October 24, 2020, 09:08:03 pm »
 Yeah, the dowels come out pretty easy with vice grips
 tap right back in.
 LUK is good quality.
 Not sure I'd name my auto parts company LUK ,...
 or FAG for that matter, ha.
Reply #35October 26, 2020, 06:41:15 pm
monst
  • 184
« Reply #35 on: October 26, 2020, 06:41:15 pm »
GTK...
Yeah, dropped it off somewhere... he will look at it and let me know a price tomorrow...
If it is ridiculous....  Those  Luk's...  where like 60 bucks......
I will just do that....
     (yeah have to watch out when choosing an Acronym as the name of your company ;D)
                      (Luk......  to close to Puke...)
   I have to start collecting all my new parts........
       Do you know where to get the best prices online....
I guess that is where I will get my stuff...... or at least use that as my reference...  and buy local........
  STUFF
  • Clutch kit
   (Is there an everthing kit anymore??)  you know with the bolts and maybe even the pushrod seal and bush
  • rear seal
  • input seal
  • shifter seal
  • transaxle drive flange seals
  • trans axle mount (hydraulic -- mine is fried)
  • valve cover gasket....
  • CAN YOU THINK OF ANYTHING ELSE???  WHAT MIGHT I BE MISSING???
                      If you can make recommendations  much appreciated.....
                            hypertext links  are cool! to the items.... if possible
                             or part numbers..............
     Also   yeah,, I want to re-pack the inner cv joints......
                           To what detail  (should/ can I get away with)...  doing this.......
THanks, MOnst
« Last Edit: October 26, 2020, 07:07:06 pm by monst »
Reply #36October 26, 2020, 07:37:10 pm
lovevws
  • 12
« Reply #36 on: October 26, 2020, 07:37:10 pm »
Make sure you center the clutch disc.
If you dont have the centering tool.
You can use vernier calipers to center it. Or something like that to center it.
Then tighten the flywheel to the pressure plate, have it just snug enough that you can move the disc around a bit.
Reply #37October 28, 2020, 10:03:52 pm
  • 2932
« Reply #37 on: October 28, 2020, 10:03:52 pm »
Runnin on LUK, ha.
 Most people don't think to center the disc the push rod presses against.
 I run a bic pen around the outside.
 In the space between the disc and pressure plate.
 Parts places for the 1.6 stuff.
 Lately I've been using rock auto or autohaus.
 Or the local NAPA.
 Sometime oreilly.
Reply #38October 30, 2020, 10:23:31 pm
monst
  • 184
« Reply #38 on: October 30, 2020, 10:23:31 pm »
GTK, Thanks!
  Yeah, Bought somewhere else...
Sorta got strung along.....  That is when I just came out and said...  Will it be more than a Franklin to cut the flywheel?
I even told him that the guy with a jig set up specifically for that flywheel wanted 150. His eyes lit up when I said I can get a new one for 60 samolians.......
Anyway,   I have to collect parts still, been sidetracked with other crazy projects........
Can anyone chime in the list above regarding parts?
thanks, Monst
« Last Edit: October 31, 2020, 08:08:33 pm by ORCoaster »
Reply #39October 31, 2020, 04:19:15 pm
« Reply #39 on: October 31, 2020, 04:19:15 pm »
  • Clutch kit
  • rear seal
  • input seal
  • shifter seal
Push rod bushing:  020311107C
Push rod seal:  020311108A
Clutch kit:  Sachs K0028-03 (that's the last one I got for my '79 rabbit - I believe it would be the same for you but confirm before ordering)
Trans end cap:  020141073A
Pressure plate to Crank bolts:  N90206103
Reply #40October 31, 2020, 05:41:05 pm
  • 2932
« Reply #40 on: October 31, 2020, 05:41:05 pm »
 A '79 Rabbit might have the 180mm clutch instead of the 200mm behind the later 1.6D.
Reply #41November 03, 2020, 08:32:11 pm
monst
  • 184
« Reply #41 on: November 03, 2020, 08:32:11 pm »
Thanks!
  Be ordering stuff sometime this week....
Buying a new FlyWheel I will.......   Second place didn't work out.....
  Vin: K   and Vin:A   might have to do with the 8 digit....
  which is this.....
                   4th – 8th Character – The next five characters tell you all about vehicle itself. The characters vary between automakers, but for the most part, the letters and numbers include information about the body style, engine type, model, series and more.
                 I am wondering
          I ran a compatibility  check for the flywheel   below is what the results are.....
    Josephina is a 1991 Vw Diesel jetta 1.6l naturally aspirated...
RESULTS:::::::::::
Compatibility
To confirm that this part fits your vehicle, please choose a vehicle from the "My Garage" list OR enter your vehicle’s details below.
My Garage
Select a vehicle
Go to My Garage
or
Year   Make   Model   Trim   Engine
1991
Volkswagen
Jetta
GL Sedan 4-Door
1.6L 1588CC 97Cu. In. l4 DIESEL Naturally Aspirated
[show all compatible vehicles]
This part is compatible with 2 vehicle(s) matching 1991 Volkswagen Jetta GL Sedan 4-Door 1.6L 1588CC 97Cu. In. l4 DIESEL Naturally Aspirated.
Notes
Important part details   Year   Make   Model   Trim   Engine
***Single Alignment Dowel Pin 7.4x1.75mm - Also Use 027 198 141E Clutch Kit Or 027 141 026C Plate; Engine: VIN: A; Transmission: Manualless   1991
***Single Alignment Dowel Pin 7.4x1.75mm - Also Use 027 198 1...more   1991   Volkswagen   Jetta   GL Sedan 4-Door   1.6L 1588CC 97Cu. In. l4 DIESEL Naturally Aspirated
Portions of the information contained in this table have been provided by autopartsgeek (they are the seller... listing is E  bay)
Item specifics
Condition:   New   Brand:   LUK
Application:   Volkswagen Jetta Flywheel   Part Number:   76524KT
Product Name:   Flywheel   Warranty:   12 Month Warranty
CS-SKU:   400:76524KT   Years:   1997 1996 1986 1983 1984 1985 1987 1988 1989 1990 1991 1992 1993
   What do you think.....??????
                                                   I could call partsgeek? do they pick up phones????
thanks, MOnst
Reply #42November 03, 2020, 09:46:21 pm
  • 2932
« Reply #42 on: November 03, 2020, 09:46:21 pm »
 I don't know the part numbers.
 Just 200mm and the smaller center splines than the 16V trany mainshaft used.
« Last Edit: November 22, 2020, 04:43:38 pm by fatmobile »
Reply #43November 21, 2020, 09:27:02 pm
monst
  • 184
« Reply #43 on: November 21, 2020, 09:27:02 pm »
Thanks!...
    Yeah, my time(which is spread of many many catastrophes all the time)
just passes by this set of wheels up on jack stands in the garage......
Soon I will delve back in......
            So I measure the clutch.... as you are saying  200mm & smaller splines......
