Fixmyvw.com
Author Topic: Aaz pump and injectors on 1.6  (Read 1367 times)
May 24, 2020, 04:05:31 pm
Wltrc
  • 29
« on: May 24, 2020, 04:05:31 pm »
Like the title says I'm wondering if 1.9aaz pump and injectors can be run on a 1.6na engine.
My injection pump is leaking badly behind the pulley do to a worn out shaft (lots of slop side to side)
I've got a seized aaz engine with a good pump and injectors on it
Thanks
Reply #1May 24, 2020, 08:53:25 pm
  • 3416
Re: Aaz pump and injectors on 1.6
« Reply #1 on: May 24, 2020, 08:53:25 pm »
The early AAZ pump with sprocket can be used on the 1.6.  The later AAZ pump has a two part hub/sprocket and will not fit the 1.6 bracket.  The delivery valves might not match and so they might need to be swapped or lines bent.  The 1.6 injectors can be used.  The AAZ injectors could also be used but they are dual stage and you would need to bend the fuel lines.
Reply #2May 25, 2020, 10:57:24 am
Wltrc
  • 29
« Reply #2 on: May 25, 2020, 10:57:24 am »
Thank you for the reply! Ive got the later aaz pump so i guess ill have to look at other options. I didnt take the brackets into consideration since my 1.6 didnt have one installed when i acquired it. now that i found one and bolted it on i see what you mean
S-PAutomotive.com
